My PC Stopped Working After Power Outage - What Could Be the Problem?
  • Thread starter Thread starter pivoxa15
    pc Power
A PC that fails to turn on after a power blackout may indicate damage to the power supply, especially if the monitor shows a blank screen but powers on. The issue can sometimes be resolved by unplugging the unit for about 10 minutes, allowing any internal circuits to reset. This reset is necessary because some power supplies have a lockout feature that activates when output lines fall outside specified limits, preventing the system from powering on until the stored charge is dissipated. If the power supply is permanently damaged, it may reactivate the lockout upon attempting to power on again. In this case, the initial troubleshooting worked, suggesting the power supply was indeed the problem.
pivoxa15
My PC suddenly stopped working after a power blackout. I.e. The PC didn't turn on even after the power went back on. It is as if it is dead.
It is about 6 years old. What could be the problem? The monitor still turns on but obviously no pictures just a blank screen. Would could be the problem? Could the processor had been 'over clocked' so its life time was reached?
Computer science news on Phys.org
Chances are your power supply got damaged.
Unplug it, wait 10 minutes, then plug it back in.
Some units can lock out.
If that doesn't help then replacing the power supply might fix things up.
Depends on if anything else got damaged.
Thanks for the advice, it worked by pluging it back in after a while. So you were most likely right about the damage to the power supply.
Could you possibly explain some of the theory behind what just happened? What do you mean by some units can lock out?
If the power supply detects that one or more output lines are not maintained within specified limits then a circuit is activated that shuts the oscillators down.
This condition will remain until the supply is unplugged and all stored charge dissipates (the only way to turn off the lockout switch).
If there is a permanent problem then the circuit will get reactivated when you try to turn the power supply back on.
Since it works now, all is good. :smile:
Thread 'Urgent: Physically repair - or bypass - power button on Asus laptop'
Asus Vivobook S14 flip. The power button is wrecked. Unable to turn it on AT ALL. We can get into how and why it got wrecked later, but suffice to say a kitchen knife was involved: These buttons do want to NOT come off, not like other lappies, where they can snap in and out. And they sure don't go back on. So, in the absence of a longer-term solution that might involve a replacement, is there any way I can activate the power button, like with a paperclip or wire or something? It looks...
In my discussions elsewhere, I've noticed a lot of disagreement regarding AI. A question that comes up is, "Is AI hype?" Unfortunately, when this question is asked, the one asking, as far as I can tell, may mean one of three things which can lead to lots of confusion. I'll list them out now for clarity. 1. Can AI do everything a human can do and how close are we to that? 2. Are corporations and governments using the promise of AI to gain more power for themselves? 3. Are AI and transhumans...
