PDE Wave Equation/boundary condition question
walter9459
I need to visualize the wave equation with the following initial conditions:
u(x,0) = -4 + x 4<= x <= 5
6 - x 5 <= x <= 6
0 elsewhere
du/dt(x,0) = 0
subject to the following boundary conditions:
u|x=0 = 0
I'm not sure I understand the boundary conditions as they written can someone help me?
Not sure where to start with the boundary conditions.
This represents a semi-infinite string tied down at the origin and given a triangular displacement between 4 and 6. So at time t = 0 the string looks like this:
It is on the x-axis from (0,0) to (4,0) then goes on a slope 1 straight line to (5,1), then on a slope -1 back down to (6,0), then out the x axis.
The du/dt(x,0) = 0 statement says the string is released from rest, not given an initial velocity.
Th boundary condition u|x=0 = 0 would be better written as u(0,t) = 0 for t >0 which says the string is tied down at the end.
Have you studied D'Alembert's solution and how to handle semi-infinite strings with it? That's where you need to look.
im sorry if I am doing wrong by posting in a another thread,but i have a similar problem...
its an infinite string which is straight ( U(x,0)= 0) and has input velocity defined by some arbitrary function g(x)...
from this conditions i have to derive
http://wiki.fizika.org/w/images/math/e/5/6/e567728fec46f565bb53595c63035ec9.png
(sorry,dont know Latex)
where c is (obviously) its velocity...
im having problem with boundary conditions...well,everything tends to cancel out :biggrin:
If you start with the the 1-dimensional wave equation for the vibrating string:
u_{tt} = c^2 u_{xx}
have you studied the D'Alembert substitution:
r = x + ct,\, s = x - ct
yet? This leads to the equation:
u_{rs} = 0
which leads to the solution you are seeking. Perhaps if you show what you have done so far I would know where to help you.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
