Perception of faster than light travel?
metal_maniac
I'm currently taking a modern physics course, I came across this problem which really threw me off guard:
Three spaceships A, B, and C are in motion as shown in the figure. The commander on ship B observes ship C approaching with a relative velocity of 0.83c. The commander also observes ship A, advancing in the rear, with a relative velocity of 0.48c. As measured by commander on ship B, at what speed is ship A approaching ship C?
Attempt at a solution: I used the transformations equations which resulted in a value of 0.94c.
observed velocity = [(-0.83c) - 0.48c]/[1-(0.83c*0.48c/c^2)] = 0.937c
0.94c was one of the possible answers so I picked it... it was wrong.
The correct answer was 1.3c.
Is this even possible?
I do suppose that someone with no knowledge in physics would just add the two velocities like it was Galilean transformations, but we're taking about the commander of a ship, pretty sure he wouldn't just add them together.
Is this just a badly written question or am I missing some things in my understanding? Any help is appreciated!
Thank you
The relativistic formula for addition of velocities is used when you want to change frames.
Here things are different. You're actually calculating the closing speed of spaceships A and C in the B's frame. He sees A to travel at 0.48c and C to travel at 0.83c, so if he attempts to find the time derivative of the distance between the two, he has no way other than simply adding their velocities.
I should say that this doesn't violate SR since there is no mass or energy going faster than light!
Take a look at here for more information!
You're a life saver!
I was stuck on this question for so long, and my textbook had no explanation for it.
Thank you so much!
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
