What is the Relationship Between Perimeter and Area in an Infinite Staircase?
  • Thread starter Thread starter macbowes
    Area Relation
The discussion explores the relationship between perimeter and area in the context of an infinite staircase, questioning whether it is possible to maintain the same perimeter while infinitely reducing the area. It highlights that while infinitely creating corners can approximate a perfect curve, the resulting shape remains jagged, leading to a discrepancy between the values of 4 and pi. The conversation references the behavior of regular polygons, noting that their perimeter remains constant at 4 while their area approaches that of a circle. Additionally, it compares the staircase problem to the convergence of stairsteps to a straight line, emphasizing that the total length remains 2, not the straight line's length of √2. The conclusion drawn is that the stairsteps do indeed converge uniformly to the line.
macbowes
Alright, so I was just browsing 4Chan and I came across this post.
[PLAIN]http://img121.imageshack.us/img121/5374/1291537737867.jpg
I realize infinitely making corners out of corners may result in an approximation of a perfect curve, however, it will always be jagged and thus result in the difference between 4 and pi.
My question is, can you maintain the same perimeter while infinitely reducing the area? Cause that's what it appears to be doing in the picture.
Mathematics news on Phys.org
https://www.physicsforums.com/showthread.php?t=450364
Approximations by regular polygons will also always be jagged, but the limit is pi.
The perimeter will polygon will always equal 4. The area, of the polygon, however, will come infinitely close to the area of the circle. At least that's my understanding.
That's a variation on the problem where you take more and more "stairsteps" from (0, 0) to (1, 1) getting a figure very close to the straight line from (0, 0) to (1, 1) but showing that the total length is always "2", not the length of the straight line, [math]\sqrt{2}[/math]. Essentially, the problem is that the stairsteps do not converge uniformly to the line.
They do converge uniformly to the line.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
