Period of a Pendulum on the Moon
The period of a pendulum is governed by the equation T=2π√L/g, where g represents gravitational acceleration. On the Moon, gravity is one-sixth that of Earth, which affects the pendulum's period. A pendulum with a 4.9-second period on Earth would have a longer period on the Moon due to the reduced gravitational force. The discussion highlights a calculation error, emphasizing that as g decreases, T must increase. Understanding this relationship is crucial for accurate pendulum period calculations on different celestial bodies.
imccnj
I need help and clarification about "Period of Pendulum on the moon"
T=2π√L/g
The equation that governs the period of a pendulum’s swinging. T=2π√L/g
Where T is the period, L is the length of the pendulum and g is a constant, equal to 9.8 m/s2. The symbol g is a measure of the strength of Earth’s gravity, and has a different value on other planets and moons.
On our Moon, the strength of earth’s gravity is only 1/6th of the normal value. If a pendulum on Earth has a period of 4.9 seconds, what is the period of that same pendulum on the moon?
What specific question do you have?
I am getting 12 as an answer when the right answer is 2
Please show your work then. We can't tell where your mistake lies if we can't see what you did. Also, don't forget the units.
I think you are right. It is clear from the equation that if g is smaller, T must be greater.
Tm/Te = √(ge/gm)
I think "they" have mistakenly multiplied the period by √(gm/ge).
Likes vela
T=2π√L/g
T = 4.9 g = 9.8
g = (T/2 π)2 = L
9.8 (9.8/2 π)2 = 5.96 = L
T = 2 π √L/g
12 = 2 π √5.96/1.64
Other than the lack of units and a few obvious typos, your work looks fine. As @mjc123 points out, you should expect from the formula the period to increase as ##g## decreases. Intuitively, if the weight of the mass decreases, the restoring torque decreases as well, so you would expect it to take longer to oscillate.
Thank you for your help and clarification.
  • · Replies 20 ·
  • · Replies 27 ·
  • · Replies 32 ·
  • · Replies 21 ·
