Period of an Oscillating Particle
The discussion focuses on deriving the velocity and period of a particle oscillating in a symmetric potential. The velocity is expressed in terms of potential energy and mass, leading to the equation v = √(2(U(A) - U(x))/m). To find the period, the relationship between time and displacement is established through integration, resulting in the integral form for the period. The key challenge involves understanding how to manipulate the differential equation and apply definite integrals to find the time taken for the particle to travel specific distances. Ultimately, the discussion emphasizes the importance of correctly interpreting the relationships between displacement, time, and velocity in the context of oscillatory motion.
robertjordan
A particle oscillates with amplitude A in a one-dimensional potential that is symmetric about x=0. Meaning U(x)=U(-x)
First find velocity at displacement x in terms of U(A), U(x), and m.
Then show that the period is given by ##4\sqrt{\frac{m}{2U(A)}}\int_0^A \frac{1}{1-\frac{U(x)}{U(A)}}dx##
(hint: ##dt=\frac{dx}{v}##)
Total energy = ##U(x) + \frac{1}{2}mv^2##
Period = time it takes to complete an oscillation
I found velocity by noting that at x=A, all the energy is potential, so total energy of the system (which doesn't change) is U(A), so we can set up the equation:
##U(A)=U(x)+\frac{1}{2}mv^2## and solving for v we get:
##v=x'=\sqrt{\frac{2(U(A)-U(x))}{m}}##.
Now I was thinking we could multiply the velocity at x=0 by Δt, then do v(0)Δt+v(Δt)Δt, and then v(0)Δt+v(Δt)Δt+v(2Δt)Δt and so on and so forth... this will help us find how far the particle has traveled at any time t. But obviously the right way to do the above process is by integrating our ##v## equation with respect to time, which will give us distance traveled over that time which will let us know how long it takes to travel A distance (1/4 of an oscillation).
##\int_0^t v dt = \int_0^t \sqrt{\frac{2(U(A)-U(x))}{m}}dt##
But we know ##\frac{dx}{dt}=v## so we can write ##dt=\frac{dx}{v}##...
umm... I'm stuck...
You have a differential equation in the form ## \frac {dx} {dt} = f(x) ##. How do you integrate it?
If unclear, try these simple examples: ## f(x) = a + x ##, ## f(x) = x^2 ##.
Since the input into our velocity equation we found is x not t, I should edit:
Now I was thinking we could multiply the velocity at x=0 by Δt, then do ##v(0)Δt+v(Δt)Δt##, and then ##v(0)Δt+v(Δt)Δt+v(2Δt)Δt## and so on and so forth...
... to say:
Now I was thinking we could multiply the velocity at x=0 by Δt, then do ##v(0)Δt+v(v(0)Δt)Δt##, and then ##v(0)Δt+v(v(0)Δt)Δt+v(v(0)Δt+v(v(0)Δt)Δt)Δt## and so on and so forth...
See how as we make Δt smaller and smaller, the above becomes a better and better approximation of displacement x as a function of time? But I don't know how to turn that method into an integral?As for integrating ##\frac{dx}{dt}=f(x)##, if we do ##\int \frac{dx}{dt}dt=\int f(x)dt##, we get ##x(t)=\int f(x)dt##... (don't know how we could evaluate that integral.)
Whereas if we do it ##\int \frac{dx}{dt}dx = \int f(x)dx## I don't know what the left side would be and we'd have to evaluate the right side.
How are either of these useful to me?
Have you studied differential equations? Separation of variables sound familiar?
##\frac{1}{f(x)}dx=dt##
##\int f(x)^{-1} dx = \int 1 dt=t##
is that right?
That would give us time as a function of velocity which can give us velocity as a function of time?
Then we can integrate that with respect to t to find displacement as a function of time?
thanks for the quick response btw
What would that have to do with velocity? Is x velocity?
oh whoops the integral of velocity is displacement so we would have x(t). So we could solve x(?)=A and then multiply it by 4 to get the period?
You will have t(x) for sure. Whether you can convert that to x(t) depends on U(x).
But if you just need to get the period, you don't need x(t). t(x) is exactly what you need in this case.
I'm afraid I don't get what it means to take ##\frac{dx}{dt}=f(x)## and turn it into ##\frac{1}{f(x)}dx=dt.
And thus I don't get what it means to then take the integral of both sides of that...
can you help me make sense of what those procedures mean?
In #2, I suggested a couple of examples. Try them.
If ##\frac{dx}{dt}=a+x## then ##\frac{1}{a+x}dx=dt## (whatever that means), so ##\int \frac{1}{a+x} dx = \int dt = t##. So ##ln(a+x)=t##.
If ##\frac{dx}{dt}=x^2## then ##\frac{1}{x^2}dx=dt## (once again idk what exactly I'm doing there), so ##\int \frac{1}{x^2}dx = \int dt##. So ##-\frac{1}{x}=t##.
But I still don't get how to solve the original problem...
What is a "period" and how much of it is spent when the particle moves from 0 to A?
"Period" is the time it takes for the particle to make one cycle. The particle traveling from 0 to A takes 1/4 of the time it would take to travel the whole period.
But I don't see how we can find the time it takes the particle to travel from 0 to A? We have this equation that gives us time:
##\int \sqrt{\frac{m}{2(U(A)-U(x))}}dx = t##
... but I don't get what the left hand side is a function of? Like how would I plug in A to the LHS without having to evaluate that integral?
Apparently the answer might be to make it a definite integral we would have to make both sides of ##\int \sqrt{\frac{m}{2(U(A)-U(x))}}dx = \int dt## definite integrals and I don't understand what the boundaries on both sides would be... Would we have to make them match up somehow? But the right hand side is a function of x and the LHS is a function of t...?
thanks for sticking with me
What you really have is ## \frac {dt} {dx} = f(x) ##. Which pretty much defines ## t(x) = F(x) ##, where ## F(x) = \int f(x) dx ##. You could also use definite integrals, then you would have, by the fundamental theorem of calculus, ## t(b) - t(a) = \int_a^b f(x) dx ##.
Sorry, how do we have ## \frac {dt} {dx} = f(x) ##?
Poor choice of symbols o n my part. Originally I wrote ## \frac {dx} {dt} = f(x) ##, which is equivalent to ## \frac {dt} {dx} = g(x) = \frac 1 {fx(x) } ##.
Then ## t(x) = \int g(x) dx ##, and ## t(b) - t(a) = \int_a^b g(x) dx ##.
