Permanent Magnet Pump Speed Control
A user seeks to reduce the speed of a submerged magnetic water pump currently operating at 8500L/hr by lowering the AC supply frequency. The pump features a magnetic rotor connected to a propeller, and the user desires a rheostat-like solution for adjustable speed control. A suggested circuit schematic for a 230V, 17-watt motor is provided, which can handle the pump's power requirements. The circuit is rated for 10 A at 120V, indicating it can manage the low current draw of the pump. Additional resources for AC motor speed control circuits are recommended for further exploration.
Cudaxtreme
Hi,
I have a submerged magnetic water pump that is pushing too much water at 8500L/hr. I know that the propeller rpm depends on the frequency of the AC supply but how can I build a simple circuit to reduce the frequency?
Thanks :smile:
Could you brief me about ur device so that I can try to figure out some way of reducing the frequency.? How does your pump work?
Sridhar
Its has a magnetic rotor that will spin when switched on, this rotor is connected to a propeller that pushes the water. I need something that can reduce the frequency of the AC supply so that the propeller will spin at a lower rpm. The best solution would be something like a rheostat where I can adjust the speed with a turn of a knob.
Do you know the current rating of the motor?
I found this schematic that you might be able to use.
http://www.electronics.50g.com/cacspeed.htm
Its a small pump, rated at 17watts/230V/50Hz.
I would need something for 230V
Thanks!
Sorry, I shouldn't assume 110/120 V.
Not much current draw at all. That control circuit is rated at 10 A at 120V. The maximum power it can handle is 1200W. Since your motor is rated at 17 watts, it would have no problem handling the power requirements of your pump at 230V.
A google search for "AC motor speed control" will yield lots of hits if you want to look for other circuit designs.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
