Permanent Magnets: Electromagnetic Wave Propagation?
A permanent magnet generates a static magnetic field that does not propagate as an electromagnetic wave, resulting in a frequency of zero unless the magnet is moved. When the magnet is shaken, the field oscillates, creating a changing magnetic field that can produce electromagnetic waves. Discussions on magnetic shielding indicate that shields are typically used for alternating fields, but some sources claim they can also shield static fields from permanent magnets. Simulations suggest that a layer of nickel can effectively shield the field of a permanent magnet. The debate continues on the effectiveness of shielding for magnetostatic fields versus alternating fields.
miloko
Hi all,
I have this simple question that I never really understood. A permanent magnet generates a magnetic field around itself. Is there an electromagnetic wave propagation associated with this permanent magnet? If so, what is the frequency of the wave?
Thanks,
Mike
Under current knowlege, the frequency is zero(it does not alternate with a permanent magnet) but the propagation of the magnetic field is at the speed of light.
The field is static and unchanging (magnetostatic) if the magnet is not moved. If you begin shaking it, then the field undergoes an oscillation with the frequency of the shaking.
- Warren
In other words, a "wave" occurs when the field changes. A regular change in a magnetic field causes a regularly changing electric field which produces a regularly changing magnetic field which produces ... (that's why the waves are called electromagnetic waves). With a permanent magnet, there is no changing field and so no wave.
Hi all,
In one of the books I'm reading, it says that shields are only used in the presence of alternating fields. However, in some websites, I see people using magnetic shields for permanent magnets which has a magnetostatic field. I ran some simulations, and the filed of a permanent magnet seems to be shielded by a layer of nickel. So, who's telling the truth?
Thanks,
Michael
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
