Permeation of water vapor through seals: vacuum vs dry gas
Water vapor permeation through polymer seals occurs at the same rate in both vacuum and dry nitrogen environments, as permeation rates are primarily influenced by the partial pressure of the gas. The presence of positive pressure in the nitrogen chamber does not significantly slow down water vapor ingress compared to a vacuum. The key mechanism involves water molecules scattering through the polymer matrix rather than colliding with gas molecules. At the inner surface of the seal, water is more likely to diffuse out into the chamber rather than back into the polymer. This understanding highlights that equilibrium will be reached where the rates of diffusion in and out balance each other.
DragonFire
From reading about the permeation of gasses through polymer seals, I am led to believe that given two identical sealed chambers, one containing a vacuum and the other pressurized perfectly dry nitrogen, water vapor would permeate through the seals and into the chambers at the same rate. This would occur because permeation rates depend only on the partial pressure of the gas in question.
Is my understanding of the phenomena correct? Intuitively, I would have thought that the positive pressure of the second chamber would lead to a slower ingress of water vapor than the negative pressure of a vacuum.
I am not read up on the subject but your intuition presupposes that the water molecules colliding with the gas molecules is a major factor. Within the seals the water molecules are principally scattering through the polymer matrix. The gas vs vacuum question only comes into play at the inner surface of the seal and there I imagine the water is very much less likely to be scattered back into the polymer rather than out into the chamber. Indeed water vapor inside will not affect this either except that equilibrium will arise where as much diffuses out as in.
Disclaimer: I am guessing here based on my understanding of the processes and may be totally wrong.
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
