Permittivity (background reading from Wikipedia)
Permittivity is a key concept in understanding how electric fields interact with dielectric materials, which polarize in response to these fields. When an external electric field is applied, dipoles within the dielectric align with the field, reducing the overall electric field inside the material. The negative end of the dipole aligns with the positive charges of the external field, creating a net effect that can lead to a zero electric field if opposing fields are equal. This polarization effect is crucial for applications involving capacitors and other electrical components. Understanding these interactions is essential for grasping the behavior of dielectrics in electric fields.
jeff1evesque
Background reading from Wikipedia
I read the following from Wikipedia,
"Permittivity is a physical quantity that describes how an electric field affects, and is affected by, a dielectric medium, and is determined by the ability of a material to polarize in response to the field, and thereby reduce the total electric field inside the material. Thus, permittivity relates to a material's ability to transmit (or "permit") an electric field."
Question
How does a dielectric's dipole becoming polarized
...thereby reduce the electric field inside the material.
Look at the electric field between the separated parts of the dipole... doesn't it go the opposite way of the overall field?
I am not sure, could you elaborate more. All I know as of now is that dipoles are not necessarily aligned, and when the electric field is applied (I think?), then the dipoles align.
Thanks,
JL
Right. In what direction do they align, in terms of polarity, with respect to the applied external E field?
The negative end of the dipole matches with (in the direction) of positive charges (capacitor or other dipoles)? And between a capacitor, could there be many dipoles spanning the distance between the two plates ?
Okay, and when you have one electric field oriented in one direction and another in the opposite one the net field is...?
Got it, zero (if they are equal-which they are in this situation).
Thanks,Jeff
