What is the Physical Meaning of Permittivity of Free Space?
In summary, the permittivity of free space, denoted by εo, is a SI unit conversion factor between Newtons, meters, and Coulombs. It does not exist in other unit systems and has no physical meaning other than converting units. It is different from the permittivity of a material, which is a measure of how a material affects an electric field by its presence. In this context, susceptibility is a measure of the ease with which a material may be polarized.
gracy
2,486
83
Astronomy news on Phys.org
It is simply a SI unit conversion factor between Newtons, meters, and Coulombs. It does not even exist in other unit systems, like Gaussian units.
Likes gracy
what it does?
It converts units of Coulombs to units of Newton's and meters.
how?
But I thought it is something abut allowing electric field to enter in a region.
It is just a unit conversion factor, and only in SI units. In Gaussian units charge is defined in terms of the dyne and cm such that there is no similar conversion factor.
You may be thinking about the permittivity of a material, but free space is not a material.
Likes gracy
Ok what is permittivity of material?
I think you already have a separate thread on that. It is not a good idea to have two open threads discussing the same topic. Let's keep this thread for vacuum questions and the other thread for material questions.
But that thread was about susceptibility not permittivity.
Ok, susceptibility and permittivity are related but not the same thing.
More importantly, vacuum and material are not the same thing.
yes.
What each term indicates in your equation?
##ε##= permittivity of a material
εo=permittivity of free space/vaccum
χe =susceptibility of ?
gracy said:
What actually is permittivity of free space I know it is εo and I know it's value but I want to know it's physical meaning,what does it actually do ?
According to my understanding, permittivity is a measure of charge required to create an electric field in a dielectric. It is not the physical definition but certainly helped me understand its applications.
The material..
In this video example, a slab of conducting material is placed in vacuum and subjected to an electric field E. Due to this field, there will be rearrangement of the charges on the slab surfaces to make the field inside the slab 0. Due to rearrangement, there will be charge densities created on opposite faces. Now, this charge density will be of the lowest possible value in case of vacuum(εo is the lowest). If this slab were placed in water(higher ε), the charge density required(or allowed) to create the same electric field E would be higher (εr times).
This is the principle used in the capacitors.
Likes gracy
Susceptibility is a measure of the ease with which a material may be polarized defined by the equation
P = ε0χE
with χ = K -1 K being the dielectric constant of the material and the permittivity ε = (1 + χ)ε0
Thus permittivity is a measure of how a material affects an electric field by its presence. since
D = εE since D is the electric field due to free charges and E is the net field in the presence of a dielectric.
What is permittivity of free space?
Permittivity of free space, also known as the electric constant, is a physical constant that describes the ability of a vacuum to permit the flow of electric field. It is denoted by the symbol ε0 and has a value of approximately 8.85 x 10^-12 F/m.
How is permittivity of free space measured?
Permittivity of free space can be measured experimentally by using a parallel plate capacitor with known dimensions and applying a known voltage. The capacitance of the capacitor can then be calculated using the formula C = Q/V, where Q is the charge and V is the voltage. The value of ε0 can then be calculated using the formula ε0 = C/d, where d is the distance between the plates.
What is the significance of permittivity of free space?
Permittivity of free space is an important constant in the field of electromagnetism as it relates the electric field to the electric displacement in a vacuum. It is used in various equations, such as Coulomb's law and Gauss's law, to calculate the strength of electric fields and the behavior of electric charges in a vacuum.
How does permittivity of free space differ from permittivity of a material?
Permittivity of free space is a constant that applies to a vacuum, which is a medium with no matter. On the other hand, permittivity of a material, also known as relative permittivity or dielectric constant, is a measure of a material's ability to store electrical energy in an electric field. It is a dimensionless quantity that is relative to the permittivity of free space and varies for different materials.
What factors can affect the value of permittivity of free space?
Permittivity of free space is a fundamental constant that is not affected by any external factors. However, its value can be affected by the choice of units used to express it. For example, its value may differ when expressed in SI units versus CGS units. Additionally, the value of ε0 may change with advancements in technology and more precise measurements.
  • Electromagnetism
  • Astronomy and Astrophysics
  • Classical Physics
11K
