Finding the Set of Permutable Matrices with Algebra
  • Thread starter Thread starter esmeco
To determine the set of permutable matrices with a given matrix A, one must find matrices X such that AX = XA. A key point is that for a matrix to be permutable, it typically requires that all rows and columns are consistent in structure. The discussion suggests that if matrix X has the same dimensions as matrix A, there could be infinitely many exchangeable matrices. The example provided illustrates a potential structure for such matrices. Understanding the properties of matrix multiplication is crucial for identifying these permutable matrices.
esmeco
I have this question as homework from my Algebra class:
A square matrix X is called exchangeable with A if AX=XA.Determine the set of permutable matrices with
My question is,how do I find that set?I know that a matrix to be permutable all rows and columns must be the same and that a square matrix is composed by the same number of rows and columns.
Thanks in advance for the help!:wink:
An example of a matrix that could be exchangeable with A could be X=2 3 ?
4 5
I think there would be an infinite number of matrices exchangeable with the matrix A if the matrix has the same number of rows and columns as matrix A.
Any thoughts on this?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
