Permutations and cycles - linear algebra
Kate2010
Let \rho \inSym(n), p be prime, r be the remainder when n is divided by p (so 0\leqr<p and n=qp+r for some integer q).
1. Show that \rho^p = \iota iff the cycles of \rho all have lengths 1 or p.
2. Show that if \rho^p = \iota then |Supp(\rho)| is a multiple of p and |Fix(\rho)|\equiv r(mod p).
Fix(\rho) := {x|x\rho = x}
Supp(\rho) := {x|x\rho \neq x}
I really don't have many ideas on these at all.
1) If all cycles have length 1 then it is clear that \rhop is the identity.
I don't know what I can deduce from all cycles having length p. The other way around, I can see if we have the identity that all cycles could be length 1, but I don't know how to go about getting length p.
2) I have no idea how to start this.
Thanks.
When you write a permutation \rho, of length n, in terms of cycles, you have:
\rho = \left(a_1...a_{k_1}\right)\left(a_{k_1}...a_{k_2}\right)...\left(a_{k_i}...a_{k_j}\right)
The cycles' lengths must sum to n and, if \rho^d = I, then all cycles must have undergone a full rotation after d iterations.
But this implies that d must divide your prime p. Now, what are the possible divisors of p?
As for (2), it's just a translation of the division n = qp + r in terms of the cycles: the cycles oh length p correspond to a factor in qp, and r = 1+1+...+1 (r times) are the cycles of length one.
Thank you so much! I've just started with permutations and as of yet I haven't really grasped it, but I do understand that now.
Another question:
If t1 and t2 are transpositions in Sym(n), then show that t1t2 = I, (t1t2)2 = I or (t1t2)3 = I (I is the identity permutation).
What condition on t1 and t2 determines which of these occurs?
What is the cycle structure of t1t2 in each case?
A transposition is a permutation that exchanges just two elements; in terms of cycles, a transposition has a cycle of length 2, and all the others of length 1.
It's immediate that any transposition t verify t^2=I; it's less immediate that they generate the symmetric group, but they do: any permutation is the product of transpositions.
For any two transpositions t1 and t2, your three cases correspond to:
(1) t1 = t2; this gives t1t2=t2t1=I.
(2) t1 and t2 are disjoint (their 2-cycles don't affect each other); in this case t1t2 is a permutation with exactly two 2-cycles (the others are 1-cycles).
(3) The 2-cycles of t1 and t2 share one common element, so t1t2 has one 3-cycle (and the rest are 1-cycles).
Thank you again!
One last question:
Let \rho be in Sym(n). For which values of n is it true that if \rho is even then \rho^m = I for some odd integer m?
Is this true for n=km where k is a natural number?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
