Perturbation: First order correction to particle-in-box eigenstates
McCoy13
First order correction to particle-in-box eigenstates for Dirac perturbation
Calculate the first three nonzero terms in the expansion of the correction to the ground state \psi^{1}_{1} for a Dirac delta perturbation of strength alpha at a/2 (box from 0 to a).
\psi^{1}_{n} = \sum_{m\neqn} \frac{\left\langle\psi^{0}_{m}\right|H&#039;\left|\psi^{0}_{n}\right\rangle}{E^{0}_{n}-E^{0}_{m}}\psi^{0}_{m}[/tex]<h2>The Attempt at a Solution</h2><br /> I started with m=2 and tried to computer the integral \left\langle\psi^{0}_{m}\right|H&amp;#039;\left|\psi^{0}_{n}\right\rangle by parts.<br /> <br /> Calculations:<br /> \frac{2}{a}\alpha\int^{a}_{0}sin(\frac{2 \pi x}{a})sin(\frac{\pi x}{a})\delta(x-\frac{a}{2})dx<br /> integration by parts<br /> \frac{2}{a}\alpha([sin(\frac{2 \pi x}{a})sin(\frac{\pi}{2})]^{a}_{0}-\frac{2\pi}{a}\int^{a}_{0}cos(\frac{2 \pi x}{a})dx)<br /> <br /> This clearly equals 0. Also, this equation indicates that the correction will be 0 for any m even.<br /> <br /> Trying m=3.<br /> \frac{2}{a}\alpha\int^{a}_{0}sin(\frac{\pi x 3}{a})sin(\frac{\pi x}{a})\delta(x-\frac{a}{2})dx<br /> integration by parts<br /> \frac{2}{a}\alpha([sin(\frac{\pi x 3}{a})sin(\frac{\pi}{2})]^{a}_{0}-\frac{3\pi}{a}\int^{a}_{0}cos(\frac{3 \pi x}{a})dx)<br /> <br /> However, this also is 0, and will be for any m odd.<br /> <br /> This clearly cannot be the correct result.
It is not. What is the integral
\int^{\infty}_{-\infty}f(x) \delta(x-x_0)dx
f(x_{0})
In this case that gives:
sin(\frac{\pi}{2}) = 1
when taking
to be the part that gets integrated in the integration by parts.
Forget "by parts" and make your life simple. Identify
<br /> f(x)=sin(\frac{\pi x 3}{a})sin(\frac{\pi x}{a})<br />
and see what you get.
Oh. That's easy. Thanks.
Just to confirm my answer, I've now got:
for m = 3
\frac{\frac{2}{a}\alpha\int^{a}_{0}sin(\frac{3 \pi x}{a})sin(\frac{\pi x}{a})\delta(x-\frac{a}{2})dx}{E^{(0)}_{1}-E^{(0)}_{3}}
= \frac{\frac{2}{a}\alpha sin(\frac{3 \pi}{2})sin(\frac{\pi}{2})}{E^{(0)}_{1}-E^{(0)}_{3}}}
= \frac{-2 \alpha}{a(E^{(0)}_{1}-E^{(0)}_{3})}
= \frac{-2 \alpha}{a(\frac{\pi^{2} h^{2}}{2ma^{2}} - \frac{9 \pi^{2} h^{2}}{2ma^{2}})}
= \frac{ma \alpha}{2 \pi h^{2}}
Where h actually stands for h-bar and m stands for mass (rather than the index).
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
