Peskin Equation (7.51): Analytic Continuation and Validity
  • Thread starter kof9595995
  • Tags
    Peskin
In summary, the conversation discusses the use of (7.51) to analytically continue the S-matrix element M(s) from the real line to the entire complex plane. It is assumed that M(s) is an analytical function of the complex variable s=E_{cm}^2. The statement M(s) ~=~ \left[M(s^*)\right]^* for s < s_0 on the real line is used to show that two analytic functions can coincide on an open subset of the real line, leading to the possibility of analytic continuation. This is a common technique in complex analysis, as seen in the theorem that states if an analytic function is equal to zero on an arc PQ, then it is equal to zero
kof9595995
679
Peskin said:
[tex]M(s)=[M(s^*)]^*...(7.51)[/tex]
This is trivially true on the real line where s<s_0. Then he analytically continued [itex]M(s)[/itex] to the entire complex plane and then made use of (7.51) off the real line. But how one can be sure (7.51) holds on entire complex plane?
They already assumed that the S-matrix element [itex]M(s)[/itex] is an analytic function of the complex variable [itex]s=E_{cm}^2[/itex].
It is a simple result in complex analysis that if [itex]f(z)[/itex] is complex-analytic, then so is [itex]\left[f(z^*)\right]^*[/itex].
Then, the statement
[tex]
[/tex]
for [itex]s < s_0[/itex] on the real line, says that two analytic functions coincide on an open subset of the real line. There is a theorem about "analytic continuation" that if two analytic functions (with different domains in general) coincide on an open subset of there common domain, each can be considered as an analytic continuation of the other into the other's domain. If it's possible to do this along two different paths from one domain to the other such that no poles are enclosed by these paths, then such an analytic continuation is unique and it makes sense to think of the whole as a single analytic function on the combined domain.
(See any textbook on complex analysis for more discussion of this.)
A (more direct) application of this is as follows (taken from Schaum's Complex Variables, problem 10.1):
Theorem: Let F(z) be analytic in a region R and suppose that F(z)=0 at all points on an arc PQ inside R. Then F(z)=0 throughout R.
Hopefully it's obvious how to apply this to the current case of [itex]M(s) - \left[M(s^*)\right]^* = 0[/itex] ?
Thanks, this is precisely what I assumed he's using, but I never learned complex analysis systematically so I didn't know.
EDIT:Emm, turns out not hard at all to prove this using Cauchy-Riemann equation, but shamefully I didn't even try.
Related to Peskin Equation (7.51): Analytic Continuation and Validity
What is the Peskin equation (7.51)?
The Peskin equation (7.51) is a mathematical formula that describes the analytic continuation and validity of a physical theory. It is used in theoretical physics to extend the validity of a theory beyond its original domain of applicability.
What is analytic continuation?
Analytic continuation is a mathematical technique used to extend the domain of a function beyond its original definition. It involves using the properties of a function, such as its differentiability, to determine its behavior in a larger domain.
Why is analytic continuation important in theoretical physics?
Analytic continuation is important in theoretical physics because it allows us to extend the validity of a physical theory beyond the conditions under which it was originally derived. This can help us to better understand the behavior of a physical system and make more accurate predictions.
How do we determine the validity of a theory using the Peskin equation (7.51)?
The validity of a theory can be determined by checking the convergence of the Peskin equation (7.51). If the equation converges, then the theory is considered valid within the extended domain. If it does not converge, then the theory may need to be modified or a more accurate equation may need to be used.
Can the Peskin equation (7.51) be used for any physical theory?
The Peskin equation (7.51) is a general equation that can be applied to many physical theories. However, its usefulness may depend on the specific properties of the theory in question. It is always important to carefully evaluate the validity of any mathematical tool before applying it to a physical system.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Topology and Analysis
