- 19,787
- 10,741
Another redirect, I’ll look into fixingStephen Tashi said:Another example:
https://www.physicsforums.com/threa...for-a-given-dynamical-system-robotics.970821/ shows as an unanswered thread in the DIY forum.
https://www.physicsforums.com/watched/threadsBuzz Bloom said:In the previous interface there was a feature that listed all the threads for which I had indicated my desire to "watch" it. That was very useful for finding older threads I wanted to read again.
Looking into it.Wrichik Basu said:@Greg Bernhardt did you remove the new videos widget in the side panel in the home page?
I faced the same in this thread:jim mcnamara said:Latex issue?
The equation run out of bounds in the OP's question:
https://www.physicsforums.com/threads/derivation-of-differential-chapman-kolmogorov-equation.972377/
You can fit the table within the space where the posts are normally visible, and enable horizontal scrolling.Greg Bernhardt said:but for the table example I'm not sure what could be done. How could that be wrapped? It should probably be converted to the new editor table. Even then it might not work. Not enough width.
I think that is something that would need to be added in the mathjax library.Wrichik Basu said:You can fit the table within the space where the posts are normally visible, and enable horizontal scrolling.
Unintuitively the field is below the message editor.Buzz Bloom said:Can anyone help me?
Hi fresh:fresh_42 said:Worked for me. I typed in "Test of # # SUB_n # # and # # SUP^m # # elements. (without the blanks)
x[sup](y[sup]z[/sup])[/sup]
That is LaTeX, not the BB-codes [sub]/[sup]fresh_42 said:View attachment 244232
No changes visible from my phone, perhaps because of the screen size as you've mentioned. Haven't checked from pc, however.Greg Bernhardt said:Let me know if that makes things better or worse.
A known issue. There is a link to the forum comment thread at the bottom of the insight.Stephen Tashi said:The page for the insight "Understanding Superposition" says I must be logged-in to comment, but I am logged-in. When I click on the "logged-in" link, I don't get any option to log-in.
It's on the ##\sqrt{x}## sign.morrobay said:What happened to the two rows of symbols, ie. Greek alphabet, math that were available with replies?
fresh_42 said:It's on the ##\sqrt{x}## sign.
Well I don't see that sqrt(x) sign in this reply page, where is it, thanksfresh_42 said:It's on the ##\sqrt{x}## sign.
Maybe a limitation on this phone but the row I have ends at the counter clockwise arrow and the row does not slide to left to sqrtx.fresh_42 said:
But I do have that on my phone. If all icons cannot fit into one line, they will make a new line:morrobay said:Maybe a limitation on this phone but the row I have ends at the counter clockwise arrow and the row does not slide to left to sqrtx.
It's a lava 550 cheap phone, android I believe. Maybe the upgrade got ahead of this phone. I have to go to internet outlets for uploading...mfb said:The operating system of the phone might be helpful to know.
If you press the back button on your browser, it will actually take you to the previous page and display it in the form that you saw before you left it. This is true for almost all web sites which don't refresh the page automatically.Borg said:Here's a couple of related bug that have been annoying me a little.
I start from this page to see unread messages - https://www.physicsforums.com/watched/threads?unread=0. If I then click the Forums tab and select Mark Forums Read, it sends me to the PF home page for some reason. Then, when I return back, the previously unread messages are still highlighted until refresh the page.
I have also seen lots of cases where threads stay highlighted after clicking on them using their link in the Alerts dropdown. I know that you have to visit the last page in the thread for them to get marked. Still, there are many times where I will return to my starting point and have to manually refresh the page in order to see which ones I haven't read yet.
LaTeX issue. Already discussed here:Stephen Tashi said:In viewing https://www.physicsforums.com/threa...ferential-chapman-kolmogorov-equation.972377/ in Firefox, I see the edit window can overflow it's right margin and be obscured by the forum self-advertising.
Screen size can make a difference.Wrichik Basu said:LaTeX issue. Already discussed here:
Lot of difference. Are you using 19" screen?OCR said:Screen size can make a difference.
That calls for the intervention of @Greg Bernhardt. Maybe put the rest of the icons in a dropdown, or add a second line of icons?morrobay said:Not that internet savvy for running around. Again why not put the sqrt(x) in place of the trite smiley faces ?
Wrichik Basu said:Are you using 19" screen?
OCR said:I use a 24" and a 22", both are Dell.
Wrichik Basu said:![]()
If you need to edit it, you can click the Report link and let them know what you need.lucas_ said:Who are the Mentors that one can request to have particular messages deleted or edited?
24 hours, see our help page.lucas_ said:For new gold member, how long is it possible to still edit or delete a message?
