Phase Difference Between Two AC Signals: Can it be Zero?
5 replies · 2K views · last reply
akash verma 1920
If i have two sinusoidal ac signals of 220V with the different phase angle i.e. there is some phase difference between them. Then can i make the phase difference zero?? Please tell
Hello akash, :welcome:
You should realize that 220 V can kill you !
What do you have available to influence the phase ? -- if anything at all
Ya i know it's dangerous, but i have to do it , Basically i have two generators who generates 220V ,1A current, and i have to add up to make it 2A, 220 volt, but the problem is that both currents are having some phase difference and this phase difference may create problem, means it can reduce the amplitude. So please tell some possible solution for this..
The generators need to be on the same shaft so they rotate together, fixed together so they rotate exactly together all the time.
Otherwise, expect it to be far cheaper to buy a new 2A generator.
Thread will remain closed because of the danger involved when an inexperienced person tries to work with AC Mains voltages.
