Phonons: For oscillator wave function
The discussion centers around the properties and implications of oscillator wave functions, particularly in the context of phonons and the infinite square well potential. Participants explore the differences between phonon oscillations in lattices and the behavior of particles in an infinite potential well, touching on concepts of temperature, particle interactions, and wave functions.
  • One participant presents equations for oscillator wave functions and questions the applicability of similar definitions in the infinite square well scenario.
  • Another participant argues that the physical nature of oscillations differs between phonons in a lattice and the wave function in an infinite square well.
  • Some participants discuss the role of temperature, suggesting it is relevant only when considering many particles, while others challenge this view by proposing that even a small number of particles could imply temperature.
  • There is a debate about whether temperature can be defined in systems with a finite number of particles, with some asserting that it is only meaningful in large systems.
  • Participants explore the implications of having fermions versus bosons in the infinite well and the potential for defining temperature in such contexts.
  • One participant suggests that the same principles could apply to nuclei in a step potential, raising questions about temperature in finite systems.
Participants express differing views on the significance of temperature in relation to the number of particles and the nature of the wave functions involved. There is no consensus on whether temperature can be meaningfully discussed in systems with a small number of particles or how it relates to the infinite square well scenario.
Participants highlight limitations in their discussions, such as the dependence on the number of particles and the nature of interactions, which remain unresolved. The implications of using different types of particles (fermions vs. bosons) and their effects on temperature and wave functions are also noted as areas needing further exploration.
LagrangeEuler
##\frac{1}{\sqrt 2}(y-\frac{d}{dy})\psi_n(y)=\sqrt{n+1}\psi_{n+1}(y)##
##\frac{1}{\sqrt 2}(y+\frac{d}{dy})\psi_n(y)=\sqrt{n}\psi_{n-1}(y)##
and I interpret ##n## as number of phonons.
Of course ##\psi_n(y)=C_ne^{-\frac{y^2}{2}}H_n(y)##.
And ##C_n=f(n)##.
Define ##\frac{1}{\sqrt 2}(y-\frac{d}{dy})=\hat{a}^+##, ##\frac{1}{\sqrt 2}(y+\frac{d}{dy})=\hat{a}##.
Why in case of infinite square well
##\psi_n(x)=\sqrt{\frac{2}{a}}\sin \frac{n\pi x}{a}##
you can not define
##\hat{a}^+\psi_n(x) \propto \psi_{n+1}(x)##
##\hat{a}\psi_n(x) \propto \psi_{n-1}(x)##
and why quants of energy in problem of infinite square well do not have a name.
Because the situations are essentially different. In the case of electromagnetic or crystal waves, we have some physically observable thing vibrating but in the case of infinite square well, it is only the wave function which is vibrating.
Also I see big difference between phonon oscillation in the lattice because in the lattice phonons are consequence of heating and in case of Shroedinger eq. ##T=0##.
No, that's wrong. At first, in the problem of infinite well, we're talking about only a few number of particles, so temperature has no meaning. But if you consider millions of particles for that problem, you can have temperature.
And another point is, Schrödinger equation is valid for any temperature!
As far as I know we take only one particle for a problem of infinite potential well. Also like in the problem of oscillator. In case of S. eq. you do not take in account temperature. So you will get the same result for any temperature. It is the same like you say I take ##T=0##. Could you really measure the same result of energy in any temperature for any single problem?
For now you take one particle. You can later solve if for more than one particle. And in statistical mechanics, you will do it for a huge number of particles. Temperature has meaning only when the number of particles is huge.So when you're doing it for only one particle, there is nothing called temperature and so you can't say in which temperature you're solving the problem.
But in the case of having a huge number of particles, temperature is only a measure of average energy so when you say high or low temperatures, you're talking about the average energy of the system which depends on the number of particles in each level and so can be considered if needed.
Temperature does indeed have a meaning for many particles, in the sense that it's connected to the system's entropy - i.e. the number of microstates the system can exist.
But couldn't we model an infinite well with (let's say) N fermions inside?
I guess you don't need N→∞ to speak about temperature... even 3 can make the deal?
Ok. It makes sence. But even in the case of large number of particles if the particles are in the same state and don't interact with each other you could say that they have one wave function and so one Sroedinger equation. Right?
Interesting. Why 3 fermions? Why not 3 bosons? Or perhaps 2 fermions or to bosons?
I avoided bosons to avoid a condensate ...
I said 3 instead of 2, because... I don't really get the idea of how 2 fermions can cause a disordering...
Well, maybe you can do that, but there isn't much use of it and you will abandon it soon. Because the machinery of statistical mechanics is designed for large number of particles.
Of course you can have any number of fermions in the well, but for them to have temperature, they should be a lot.
You always have one Schrödinger equation and one wave function and the number of particles or whether they have interaction or not doesn't matter. The difference appear in the dimensionality of the wave function(number of particles) and the Hamiltonian(Interaction between them).
I proposed that in the same way you can do it for nuclei ... assign fermions in a step potential (just generalize it for a closed box one, like an infinite well).
I guess we can define temperature for nuclei, altough the number of nucleons N is finite? (I may be wrong)
  • · Replies 29 ·
  • · Replies 17 ·
  • · Replies 21 ·
10K
