Pinchy444
- 5
1. A scientist is investigating the effect of different types of radiation on the surface of a piece of Sodium metal. He uses a freshly cut surface on a Sodium plate.
2. a) Which of the variables is the dependent and independent variables?
b) Why must the surface of the Sodium metal be carefully prepared?
3. a) I assume that the independent variable is the frequency of the light being emitted and the dependent variable is the Stopping Voltage.
b) I believe that the metal should be prepared carefully so as to avoid any impurities being found on the metal hence effecting overall experimental results. Am I correct for both questions?
Any help will be appreciated.
