Can Free Fundamental Particles Absorb Photons?
In summary, it is impossible for a free fundamental particle to absorb a photon as it would violate the conservation of both energy and momentum. This argument also holds for other fundamental particles. This is due to the fact that mass is not a conserved quantity in relativistic physics, and in order for the electron to absorb a photon, its rest mass would have to change. It is possible for the electron to change into a heavier particle, but this is not possible through irradiation with light. Instead, the electron and photon will scatter off each other in different directions.
subsonicman
I recently learned that a free electron can't absorb a photon and derived it by showing it would be impossible to conserve both momentum and energy if that were the case. It seems like the same argument would extend to other fundamental particles. Is it true that no free fundamental particle can absorb a photon?
Edit: Changed mass to momentum
The correct argument is that you cannot conserve energy and momentum for a single particle and photon together with the on-shell conditions. Mass by itself is not a conserved quantity in relativistic physics!
Oops I'm sorry, I meant to say momentum, thanks for the catch.
What happens instead, of course, is that the particle absorbs the photon and then reemits one of a different frequency.
Do you have the calculations handy or a link on the internet to show this?
It's actually pretty simple. In addition to conservation of energy and momentum, each particle must satisfy [itex]m^2 = E^2-|\vec{p}|^2[/itex]. (Note that I'm using natural units where c=1. If you want to use conventional units, multiply every m by c2 and every p by c.) For the photon, which has [itex]m_\gamma = 0[/itex], this reduces to [itex]E_\gamma = |\vec{p}_\gamma|[/itex].
For the final state of the electron (or other massive fundamental particle),
[tex]\begin{align}
m^2 &= E_f^{\phantom{f}2}-|\vec{p}_f|^2\\
&= (E_i + E_\gamma)^2 - |\vec{p}_i + \vec{p}_\gamma|^2\\
&= E_i^{\phantom{i}2} - |\vec{p}_i|^2 + E_\gamma^{\phantom{\gamma}2}-|\vec{p}_\gamma|^2 + 2E_f E_i - 2|\vec{p}_i||\vec{p}_\gamma|\cos \theta\\
&= m^2 + 2E_\gamma (E_i - |\vec{p}_i|\cos \theta).
\end{align}[/tex]
This is clearly only true if [itex]E_i = |\vec{p}_i|\cos \theta[/itex]. But, given the first equation above, this means that
[tex]\begin{align}
\sqrt{m^2 + |\vec{p}_i|^2} &= |\vec{p}_i|\cos \theta\\
m^2 + |\vec{p}_i|^2 &= |\vec{p}_i|^2 \cos^2 \theta\\
|\vec{p}_i|^2 (1-\cos^2 \theta) &= -m^2\\
|\vec{p}_i| &= \sqrt{\frac{-m^2}{\sin^2 \theta}}
\end{align}[/tex]
But, this is clearly impossible, as it would mean that the initial state electron must have had imaginary momentum, which is certainly not physically realizable.
This result presumes that the rest mass of the electron cannot change. Under this assumption, there is also this simple explanation:
Imagine the electron and photon are two little balls going towards each other in the frame where their total momentum is zero. Now if the electron absorbed the photon, the former would have to stop its motion and stand still, to conserve zero momentum. As a result, it would lose some kinetic energy. The energy of the photon would be lost too, so clearly energy could not be conserved.
Thus some assumption must be wrong. Usually, it is assumed that the rest mass cannot change, so the conclusion is that the electron cannot just swallow the photon.
However, think for a while that the electron could change its rest energy - there are muons and tauons, which are something like heavier versions of the electron. If the electron mass could increase, then electron could swallow the photon; both momentum and kinetic energy could be conserved in the absorption.
Does anybody know whether it is possible in theory/experiment to change the electron into muon or tauon by irradiating it with a light of proper frequency?
Great example, both the electron and the photon would have to come to a stop from opposite directions... But wouldn't this energy go to the bonding of the photon and electron? Does this mean light will travel through a beam of electrons as if they are not there?
Parlyne said:
... this is clearly impossible, as it would mean that the initial state electron must have had imaginary momentum, which is certainly not physically realizable.
Thank you for sharing this, much appreciated. If I understand this correctly, you are looking for (solving for) the initial momentum of the electron after the collision and finding it is impossible. It does though assume that there is no storage of energy due to the inelastic collision does it not?
Yes, but that would lead to a change of electron's rest mass. It is usually thought impossible.
In the two ball picture, if they are no a head-on collision, no; they will bounce of each other and scatter in some other directions.
Photons do not bounce. They can only be created or absorbed. And in between, travel in a straight line. You said earlier that an electron cannot just swallow a photon, but that is exactly what does happen. The result is an electron that's off the mass shell, briefly, which then emits a new photon of the same energy.
This is not possible.
So it is possible, but only for a short time? How long is that? And what prevents the electron from keeping the energy longer?
I'm going to have to disagree with Bill_K. This should, in fact, be possible; but, it should also be such a highly suppressed process that, in practice, we should never have significant enough statistics to have a reasonable chance of seeing it happen.
The problem is that changing flavors requires a W to be involved. But, since the only external particles are leptons and a photon, the W must appear in a loop; and, given that we're dealing with leptons, the loop will also need to contain neutrinos. But, this is actually where the possibility of the flavor change arises. Because neutrinos mix, it is possible to have an electron enter the W/neutrino loop and a muon or a tau exit (if the right kinematic conditions can be arranged). This process is just the time reverse of the long sought [itex]\mu \rightarrow e\gamma[/itex], which has, as yet, not been observed.
If the energy is somehow accounted for, it could be a long time. For example, if the electron had a capability to store energy on an internal basis (through internal vibration or some kind of periodic internal motion), then the photon would not reappear until the internal process broke down for some reason.
A photon can be absorbed by a free electron. The proof provided in post #6 that it cannot, is a Newtonian view that no energy is absorbed or lost due to the collision. In the words of Newton and Einstein:
A note from Newton's Principles definition #4 in 1687:
Impressed Force - This force conflicts in the action only; and remains no longer in the body when the action is over.
In Einstein's second paper on relativity in 1905, he explicitly concludes:
"Radiation carries inertia between emitting and absorbing bodies". It is important that not only does something receive a "kick" from the momentum of the energy, but the internal inertia (i.e., the inertial mass) of the body is actually increased. (from mathpages.com)
Thanks, I stand corrected!
You are misreading the argument in #6 I believe. The mass/momentum/energy relationship implied by that Einstein quote is mathematically represented by the equation in the very first sentence of Parlyne's post, the one that's the start of the derivation.
Sorry, but I disagree. He breaks the energy into before and after the collision, the momentum into before and after the collision, but leaves the mass the same before and after the collision. Einstein's quote addresses exactly that. To quote post #2 "Mass by itself is not a conserved quantity in relativistic physics!"
The rest mass of an electron IS the same before and after the collision. You're misinterpreting Einstein's quote, which is meant to apply to a macroscopic object that can have internal degrees of freedom, such as thermal energy. The rest mass of an elementary particle cannot be changed.
No, but mass and energy are together conserved. That Einstein quote refers to the way that adding energy to an object can be interpreted as the object gaining mass while the energy source loses energy, the amounts of each being related by the famous E=mc2.
In the century since Einstein wrote that, serious students of physics have learned that it's often easier to work with the (entirely equivalent) mass/energy relationship that Parlyne started with in #6:
[tex]E^2 = (m_{0}c)^2 + (pc)^2[/tex]
where m0 is the mass of the particle when it as rest so has zero momentum.
(There are some subtleties if the object in question has internal degrees of freedom so can absorb energy without changing its momentum and kinetic energy, but none of that applies here because we're dealing with electrons and photons - nice simple point particles).
The original question relates to free electrons absorbing and emitting photons.
"I recently learned that a free electron can't absorb a photon..."
If it has been proved impossible, what is going on? Or is it possible? Does it happen in experimental settings?
It does not happen in experimental settings, or anywhere else that anyone has ever noticed; and this isn't surprising because it has been proved impossible (more precisely, not possible under current theories without violating at least one of conservation of mass-energy and conservation of momentum). There always has to be some other mass nearby - that is, we're not dealing with a free electron - to soak up the excess momentum.
It works the same way in reverse as well. A gamma-ray photon cannot decay into an electron-positron pair, even if has adequate energy, if it is completely isolated.
As I have said twice already in this thread, what happens with a free electron instead is scattering - one photon is absorbed and another one is emitted.
I agree. "The result is an electron that's off the mass shell, briefly..."
1. What are free fundamental particles?
Free fundamental particles are the smallest units of matter that make up the universe. They include particles such as electrons, protons, and neutrons, which are considered to be the building blocks of all matter.
2. Can free fundamental particles absorb photons?
Yes, free fundamental particles are capable of absorbing photons. Photons are packets of energy that make up electromagnetic radiation, including visible light. When these particles come into contact with a free fundamental particle, they can transfer their energy to the particle, causing it to absorb the photon.
3. How do free fundamental particles absorb photons?
Free fundamental particles absorb photons through a process called absorption. When a photon collides with a particle, it transfers its energy to the particle, causing it to become excited. This can lead to changes in the particle's energy or movement.
4. What happens to free fundamental particles after they absorb photons?
After absorbing a photon, free fundamental particles can undergo various changes. For example, electrons can jump to a higher energy level in an atom, or protons and neutrons can change their spin. The changes that occur depend on the type of particle and the amount of energy transferred from the photon.
5. Can free fundamental particles emit photons after absorbing them?
Yes, free fundamental particles can emit photons after absorbing them. This process is known as emission and occurs when the particle returns to its original energy state after absorbing the photon. The emitted photon will have the same energy as the absorbed one, but it may have a different direction or wavelength.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Atomic and Condensed Matter
