- #71
Juan R.
- 416
- 1
jtbell said:The definition of "invariant mass" of a system of particles via
[tex](mc^2)^2 = E_{total}^2 - ({\vec p}_{total} c)^2[/tex]
is the one that is universally used among particle physicists, as far as I know. This is based on my own experience in experimental particle physics (in which I got my Ph.D.), and on some Google searches which turned up pages such as
www.hep.lu.se/staff/eerola/relativitet.pdf (see bottom of page 3)
www.yorku.ca/marko/ComPhys/RelDynamics/RelDynamics.html
(see section 8, "Invariant mass for systems of particles")
http://www.hep.man.ac.uk/u/tamsin/dzeroweb/page10.html
http://faculty.cua.edu/sober/635/relkin.pdf
(see eq. 11 on the first page)
I have yet to find any explicit mathematical definition of "invariant mass" that differs from this one.
I will not argue this point further, since it is purely a matter of semantics. I will simply try to remember in the future that when Juan refers to the invariant mass of a system, he means the sum of the invariant masses of its component particles, and will interpret his remarks accordingly.
I talked of rest mass. In fact the SR expression i used is STANDARD and m is the rest mass. I initially used the notation m0 for rest mass but i abandoned due confusion of people, perhaps now would i recover it again?
You are talking of "invariant mass" which is not rest mass, which is also invariant. At least, the name invariant mass is misleading because rest mass is also invariant. Since rest mass is both invariant and constant and "invariant mass" is just invariant but is not constant. The better name would be non-constant mass or similar.
On http://www.hep.man.ac.uk/u/tamsin/dzeroweb/page10.html
the notation W is used for "invariant mass" which is different from m i used. The web you provided says
they use invariant mass, a physical quantity involving some tricky concepts.
Perhaps the most tricky is that the vectorial character of the impulse is used in the definition, which is not the SR definition.
What is the classical relativistic Lagrangian that you use for a free particle?
In your other link
http://www.yorku.ca/marko/ComPhys/RelDynamics/RelDynamics.html
it is said in "(8) Invariant mass for systems of particles" that
The dynamic state of a relativistic system of particles can be described by the following expression for the invariant total rest mass in terms of energy and momentum
and definition used next is the same i used! :yuck:
And after says in "9) Massless particles: photons,...?"
The only particles known to be definitely massless are photons.
that is i said! :yuck:
Your link
is a bit misleading. Define invariant mass to be mass invariant in any frame but before 1.2 explicitely says that (E^2 - p^2), is also an invariant. Are two different concepts of invariant mass.
Seeing the other of your links
I do not understand because you was confounded. eq (5) is the same equation i used including notation, whereas equation 11 is the definition i use but notation is again W.
I think that you did not note that my m is also an invariant and therefore is properly the invariant mass.
Perhaps by this reason equation 11 defines "invariant mass" instead of invariant mass. The use of " is interesting.
