Physical Chemistry: Estimating ΔG of an Ideal Gas
To estimate ΔG for one mole of an ideal gas increasing pressure from 1.00 atm to 11.0 atm at 25.0°C, the relevant equation is ΔG = nRTln(Pf/Pi). The discussion highlights that the problem does not specify whether the gas is monatomic or diatomic, which raises questions about the applicability of certain equations. Although the heat capacity (C(p,m)) is not provided, it is noted that ΔH can still be calculated. The participants confirm that the equation for ΔG is valid for this isothermal process involving an ideal gas. Overall, the focus is on clarifying the necessary parameters and equations for the calculation.
Nick_273
Estimate ΔG for the process where one mol of ideal gas is subjected to an increase in
pressure from 1.00 atm to 11.0 atm at 25.0°C.
ΔG=ΔH-TΔS
ΔH=C(p,m)(Tf-Ti
Seems straight forward, but it seems i am not given enough information to complete the problem. I need C(p,m)? It does say estimate. Does that mean that i only need to imply that the Gibbs free energy will be possitive, negative, or 0?
If you can help me clarify the problem that would be greatly appreciated!
Thanks.
Does the problem say whether the ideal gas is monatomic or diatomic?
No, it does not. Does this equation apply?
ΔG = nRTln(Pf/Pi)
I found it in my notes but can't find it anywhere in the text.
Oh, for this case, you can actually still calculate ΔH even though you do not know the heat capacity of the gas.
Hi Nick_273! :smile:
ΔG = nRTln(Pf/Pi)
Yep, it applies (for an isothermal process on an ideal gas).
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
