Physical Chemistry - vapor pressures
To determine the temperature at which isopropanol and carbon tetrachloride have the same vapor pressure, the Clapeyron equation is essential. The boiling points of isopropanol (82.5°C) and carbon tetrachloride (76.7°C) indicate their vapor pressures at 1 atm. The relationship between boiling point and vapor pressure is that boiling occurs when vapor pressure equals external pressure. Given the standard enthalpies of vaporization for both substances, one can calculate the corresponding vapor pressures at different temperatures. This approach allows for finding the temperature where their vapor pressures are equal.
belltos
At what temperature will isopropanol (Tbp = 82.5C) and carbon tetrachloride (Tbp = 76.7C) have the same vapour pressure? For isopropanol and carbon tetrachloride, the standard enthalpies of vaporization are 32.54 kJ mol-1 and 44.0 kJ mol-1, respectively.
Clapeyron Equation?
I don't really know how to get started.
You are right about using Clapeyron equation.
What does boiling point mean? How is it related to vapor pressure?
The only relationship I know between boiling point and vapor pressure is that the boiling point is the temperature where the vapor pressure of a liquid is equal to external pressure.
External pressure is 1 atm - that means you are given p1, T1 and vaporization enthalpy for each substance. That's enough to find any p2/T2 pair.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
