Physical law from experimental data
bernhard.rothenstein
Consider that high quality experiments furnish data that relate proper time intervals to coordinate time intervals for different values of the relative velocity (life time dilationf moving mesons). An inteligent computer program could find out the best function of the relative speed which relates all the experimental results, i.e. the time dilation formula. Could we use it for further relativistic derivations or it is necessary to perform other experiments (light clock) in order to derive it?
We find a simillar situation in the case of the formula which accounts for the mass dilation (Bucherer's experiment).
With that experimental data, together with the law of inertia and the uniformity of clock rates on any single world line, one can deduce Lorentz invariance, and all other consequences of relativity.
Thanks. Please be more specific concerning the law of inertia. What does it introduce in the derivation?
The law of inertia is just to determine what world lines look like in inertial reference frames. If we send particles with different velocities in different directions, and then record the event where their measure a time 1, we get the hyperbola. In light-signal coordinates, this hyperbola is \tau_1 \tau_2 = 1. By a simple argument, we can deduce that the light-signal coordinates of an event (\tau_1, \tau_2) in a frame moving with velocity v relative to the original frame are
\tau_1 ' = \sqrt{\frac{1+v}{1-v}} \tau_1
\tau_2 ' = \sqrt{\frac{1-v}{1+v}} \tau_2
Thus we get lorentz invariance: \tau_1 \tau_2 = \tau_1 ' \tau_2 '.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
