Physics banking problems w\ friction.
  • Thread starter Thread starter JeremyWsmith
    Friction Physics
A 1200-kg car is rounding a banked curve with a radius of 70m at a speed of 90 km/h (25 m/s) and an angle of 12 degrees. The calculations show that a coefficient of friction of 0.72 is necessary to maintain the car's trajectory. The force of friction acts perpendicular to the normal force. While the solution is mostly correct, it lacks an explanation of why friction is needed in this scenario. Understanding the role of friction is crucial for accurately solving banking problems in physics.
JeremyWsmith
A 1200-kg car rounds a curve of radius 70m banked at an angle of 12 degrees. If the car is traveling at 90km/h, will friction force be required? If so, how much and in which direction?
mv^2/r = Fc
90km/h = 25m/s
Fc = Fnx + uFny
mv^2/r = mgsin12 + u9.8cos12
25^2 = 9.8sin12 + u9.8cos12
u=.72; The coefficient of friction .72 and the force of friction will be perpendicular to the normal force.
Can someone confirm that this is the correct answer?
You have a few errors in writing it out, but your answer is correct. You have not explained why friction is required.
AM
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
