MHB What is the Magnitude of Force P to Keep a Block Stationary Against a Wall?
  • Thread starter Thread starter Wild ownz al
    Motion Physics
To keep a block of mass 3.00 kg stationary against a wall, a force P at a 50.0-degree angle must be applied, considering the coefficient of static friction is 0.250. The horizontal forces must balance, leading to the equation -N + F*cos(50) = 0, where N is the normal force. In the vertical direction, the friction force acts downward, and its magnitude is f = μN, which must also be accounted for in the equilibrium equations. Analyzing both the horizontal and vertical forces allows for the determination of the possible values for the magnitude of P. Properly accounting for all forces is essential for solving the problem accurately.
Wild ownz al
A block of mass 3.00kg is pushed up against a wall by a force of P that makes a 50.0 degree angle with the horizontal (REFER TO PICTURE). The coefficient of static friction between the block and the wall is 0.250. Determine the possible values for the magnitude of P that allow the block to remain stationary.
Mathematics news on Phys.org
You have an applied force which has a component in the horizontal direction. You also have a normal force directed in the opposite direction. (Let's say that N is in the negative x direction and the component of the applied force is in the +x.) The sum of these two forces must be 0 N as there is no motion in this direction. This gives you N in terms of the applied force. Thus [math]\sum F _x = -N + F~cos(50) = 0[/math].
What can you say about the vertical (y) direction? Do the same thing. A lot of stuff will cancel out.
By the way, you missed a force on your diagram. There is a friction force acting downward of magnitude [math]f = \mu N[/math].)
See what you can do with this.
-Dan
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
