How do reflectors in auditoriums improve sound quality?
In summary: So, in summary, the ceiling of a theater or auditorium can enhance the sound of a performance by dispersing the sound, or by having reflectors to break up the echo.
dreit
42
In many theaters and auditoriums some of the ceilings are concave or have things hanging from them. How does this enhance the traveling of sound?
Actually concavity would be a problem as it focuses sound making coverage uneven -- unless it's well planned in advance. Convex (arching out) surfaces are often hung over, say, orchestras in order to disperse the sound more evenly. Dangly bits might disperse or absorb, both reasonable hopes in controlling reverberation and evening out the frequency response of a room. All these effects are analogous to the way mirrors and other objects affect light, they just need to be bigger to affect sound.
But wouldn't a concave ceiling (concave as observed from the inside) help distribute sound coming from a point source. Something more along the lines of the following image.
Yeah, I thought concavity would have more of a projection effect like the image above. I guess it really depends on how the stage opens up into the actual theater.
Yes you are right...I was thinking of a spherical concave reflector which would tend to focus rather than disperse. I forgot about all those old-timey bandshells which have some kind of concavity behind the stage. The shape in the lovely drawing provided by mishrashubham would seem to do the job we need. But it's tricky because you don't always have a point-source soloist to distribute.
The http://www.dallasculture.org/meyersonSymphonyCenter/photos.asp" shows a big thing hanging above the stage where I go. It can be moved into different positions.
This concert hall was a big deal when it was first built, in terms of having good sound.
Wikipedia summarizes, "a system of canopies weighing more than 42 tons is suspended above the stage and can be raised, lowered, or tilted to reflect the sound throughout the audience chamber.[5]"
A serious problem in big buildings, particularly high ones with domed roofs, is the echo from the ceiling. Whilst reverb is nice and atmospheric, a distinct echo is bad. In the Royal Albert Hall, there are 'mushroom' reflectors, suspended at various heights, to break up a single, annoying, echo into a random set of small echos which still give the benefit of a large auditorium but without the echo problem.
In very large auditoria /ums, and in outdoor venues, a reflector overhead can improve the listening for people at the back but they can colour the sound. This doesn't matter because the 'purists' all spend a lot of money and sit up front.
What is the physics behind sound propagation indoors?
The physics of sound propagation indoors is governed by several factors such as the material and shape of the room, the temperature and humidity, and the presence of objects and furniture in the space. When a sound wave is produced, it travels in all directions and bounces off the surfaces of the room, creating reflections. These reflections can interfere with the original sound wave, resulting in changes in volume, frequency, and direction of the sound.
How do sound waves interact with different surfaces in a room?
When sound waves hit a surface, they can be reflected, absorbed, or transmitted. The amount of reflection, absorption, and transmission depends on the material and texture of the surface. Hard, smooth surfaces like walls and floors reflect sound waves, while soft, porous surfaces like carpets and drapes absorb sound waves. This can affect the overall sound quality and reverberation time in a room.
What is the impact of room size on sound propagation?
The size of a room can greatly impact the way sound waves travel and interact with surfaces. In smaller rooms, sound waves can bounce off surfaces more frequently, resulting in a longer reverberation time and a louder overall sound. In larger rooms, sound waves have more space to disperse, resulting in a shorter reverberation time and a more even distribution of sound.
How does temperature and humidity affect sound propagation indoors?
Temperature and humidity can affect the speed of sound, which in turn impacts the way sound waves travel and interact with surfaces. As the temperature and humidity increase, sound waves travel faster and can be absorbed more easily by surfaces. This can result in a shorter reverberation time and a clearer, more defined sound. On the other hand, colder temperatures and lower humidity can slow down sound waves, resulting in a longer reverberation time and a muffled sound.
What role do objects and furniture play in sound propagation indoors?
Objects and furniture in a room can affect the way sound waves travel and interact with surfaces. They can absorb, reflect, or diffuse sound waves, which can impact the overall sound quality and reverberation time in a room. For example, a room with lots of furniture and soft surfaces will have a shorter reverberation time and a more muted sound, while a room with fewer objects and hard surfaces will have a longer reverberation time and a more vibrant sound.
  • Mechanics
  • Art, Music, History, and Linguistics
