Physics or Joint Math/Physics Honours?
The discussion centers on choosing between a joint degree in Math and Physics versus a straightforward Physics degree. The joint degree is perceived as better preparation for graduate studies, particularly in theoretical physics, despite having fewer upper-level physics courses. Participants note that the first year is common to both programs, with a decision required in the second year. Concerns about the limited upper-level physics courses are addressed by highlighting the option to take additional physics electives if time permits. The conversation also touches on the academic rigor of the joint program, which is noted to be challenging, with only a few graduates each year. The participants express a shared background from Quebec and plan to enroll in the program together.
palex3
Which of the two would you recommend? I'm thinking that a joint degree in Math and Physics would be better for graduate studies, but the courses for a simple physics degree sound "more fun":
http://www.physics.mcgill.ca/ugrads/math.html
http://www.physics.mcgill.ca/ugrads/honours.html
Specifically, the last year curriculum varies. The complementary courses for Physics offer more variety, whereas it seems to me that the physics/math courses are pretty restricted (when it comes to physics). So, which one is best in your opinion?
The first year(U1) is common to both programs, so you have to choose only at the 2nd year. Basically, you replace the labs and the research project with math courses and you have less upper level physics to take. It's a good preparation for theoretical physics. It's also the hardest of the physics program, about only 5 graduate each year. Next fall I am enrolling in that program after I finish my CEGEP.
I see. The main thing that was worrying me was the lack of uper-level physics courses, but I guess I can always take whatever I'm missing as a grad student. I guess I'll see you there next fall, then!
You can take other physics courses as electives if you have extra time, you are not limited to only the classes they require.
Just to know, are you from Quebec or from somewhere else ? I'm from Quebec and I speak french as my mother tongue.
I'm in the same situation as you are.
I hadn't thought of that, but it makes sense. The required classes add up to 81 credits, and 3 years is 90 credits, so that means I have 9 other credits to take (I think), or 3 other classes (3 credits/class).
Thanks for your help!
I'm going to make this one quick since I have little time. Background: Throughout my life I have always done good in Math. I almost always received 90%+, and received easily upwards of 95% when I took normal-level HS Math courses. When I took Grade 9 "De-Streamed" Math (All students must take "De-Streamed" in Canada), I initially had 98% until I got very sick and my mark had dropped to 95%. The Physics teachers and Math teachers talked about me as if I were some sort of genius. Then, an...
Bit Britain-specific but I was wondering, what's the best path to take for A-Levels out of the following (I know Y10 seems a bit early to be thinking about A-levels, but my choice will impact what I do this year/ in y11) I (almost) definitely want to do physics at University - so keep that in mind... The subjects that I'm almost definitely going to take are Maths, Further Maths and Physics, and I'm taking a fast track programme which means that I'll be taking AS computer science at the end...
After a year of thought, I decided to adjust my ratio for applying the US/EU(+UK) schools. I mostly focused on the US schools before, but things are getting complex and I found out that Europe is also a good place to study. I found some institutes that have professors with similar interests. But gaining the information is much harder than US schools (like you have to contact professors in advance etc). For your information, I have B.S. in engineering (low GPA: 3.2/4.0) in Asia - one SCI...
