Physics Presentation: Explaining Constant Acceleration
In summary, the two objects in a free fall experience a constant acceleration due to gravity. This is because all of the factors on the right side of the equation are constant.
ACLerok
194
I found your website when looking for some help eith Physics.
November I have to make a presentation involving an experiment in
which two objects of different mass will hit the ground
simultaneously. The motion of these two objects is constant
acceleration correct? How would I easily explain why this is true to
someone? Also, since the objects hit the ground simultaneously, do
they have the same acceleration?? How would I find it? Thanks and i
hope you get the chance to help me out.
Here's a start:
My little book of formulas says, "In free-fall motion, an object experiences negligible air resistance and a constant acceleration due to gravity.
All objects in free fall at the same location above the Earth have the same acceleration due to gravity.
The acceleration due to gravity is a vector that points toward the center of the Earth and is denoted by the symbol g. Near the surface of the earth, g has a magnitude that is approximately constant and is given by
g=9.80 m/s2 or 32.2 ft/s2.
The canonical figure to two sig. figures is 9.81 ms-2,zoobyshoes (though of course it varies across the Earth's surface, but 9.81 will be correct for most places on the Earth).
Use the formula:
s = ut + ½at2
this means that if the inital velocity, u and the displacemnet s, is the same then if they take the same time they must of had the same acceleration. The motion of these two objects won't quite be constant accelarion due to drag, but if you try to eliminate as much drag as you can by using heavy objects with a small surface area, then you needn't worry too much about it.
In General 2 bodies with mass have a force of gravity given by the equation
F=GMm/r2
Where G is the gravitational constant
G=6.67e-11 Nm2/kg2
M= Mass of body 1 (let this be the mass of the earth)
m= mass of body 2 (let this be the mass of something on the surface of the earth.
r is the distance between the centers of mass. let us call this the radius of the earth.
Newton gave us F=ma, this is the relationship between the mass of a body, the force acting on it and the resulting acceleration. A body of mass m on the surface of the Earth has a gravitational force exerted on it by the first equation, if we use that as the force in Newtons law we get
GMm/r2= ma
now m is the same on each side so we can cancel it out resulting in
a =GM/r2
Notice that all of the factors on the right are constant, to find a simply compute the value on the left side. This is the quantity we call g.
I have given you G, you should be able to find values for the other quantities (Mass and radius of the earth) be sure that they are expressed in the same units as the value for G (that is kg and meters).
Originally posted by ACLerok
How would I easily explain why this is true to someone?
I suppose you are talking about an audience that isn't necessarily interested in physics, because you ask how it can be "easily" explained. The important first step is to make sure you understand it backwards and forwards yourself.
One strategy I have for this is to go to the library and compare how the same information is presented in as many different sources as I can. In this instance I'd pull all the physics textbooks they have down and read what each says on the acceleration of gravity. Encyclopedias, too.
I like the way Integral referred to Newton II as a "relationship". This is an important thing to be conscious of when you're trying to grasp, or trying to explain, what any formula is about: it expresses how the different values relate to each other. The better you understand that relationship the easier it is to explain it to a non-scientific person, in language they can understand.
1. What is constant acceleration?
Constant acceleration is a type of motion where the velocity of an object changes at a constant rate. This means that the object's speed increases or decreases by the same amount in each unit of time.
2. How do you calculate constant acceleration?
Constant acceleration can be calculated using the equation a = (vf - vi)/t, where a is the acceleration, vf is the final velocity, vi is the initial velocity, and t is the time.
3. What is the difference between constant acceleration and uniform motion?
Constant acceleration is a type of motion where the velocity changes at a constant rate, while uniform motion is when the velocity remains constant over time. This means that in constant acceleration, the speed is increasing or decreasing, while in uniform motion, the speed is constant.
4. What are some real-life examples of constant acceleration?
Some examples of constant acceleration include a car accelerating from a stoplight, a roller coaster going down a steep hill, and a rocket launching into space.
5. How does constant acceleration relate to Newton's laws of motion?
Constant acceleration is related to Newton's laws of motion in that it can be explained by the second law, which states that the acceleration of an object is directly proportional to the net force acting on it and inversely proportional to its mass. This means that in order to change an object's velocity at a constant rate, a net force must be applied to it.
  • Other Physics Topics
  • Classical Physics
