Physics problem about springs PLEASE HELP
  • Thread starter Thread starter dardar22
    Physics Springs
A 2 kg block with an additional 253 g body stretches a spring by 2.5 cm, leading to the calculation of the spring constant, which is determined to be 99.2 N/m using the formula K = F/X. For the second scenario, a 1.8 kg block with a 221 g body stretches the spring by 3.8 cm, and upon removing the body, the period of oscillation needs to be calculated. The approach involves setting up a force balance equation and using initial conditions to derive the period. The discussion emphasizes the importance of posting attempted solutions for assistance. The thread highlights the application of physics principles to solve spring-related problems.
dardar22
A 2 kg block hangs from a spring. A 253g body hung below the block stretches it a further 2.5cm. What's the spring constant? Use g=9.8N/kg. Calculate the value to 1 decimal place and use N/m as your unit.
AND
A 1.8kg block hangs from a spring. A 221g body hung below the block stretches it a further 3.8cm. If the 221g body is removed and the block set into oscillation, what is the period of the motion? Use g=9.8N/kg. Calculate the value to 2 decimal place and use second as your unit.
In order to get help, you should post an attempted solution.
Here is a hint: Write the force balance equation for a) just the first block and b) both blocks together. How can you then use these two equations to obtain an expression for k in terms of the known values?
for the second part, if I were to do it, I would set up a force balance equation (left side in terms of displacement x from the rest postion, right side in terms of acceleration = d^2x/dt^2) with initial conditons dx/dt(0)=0 and x(0)=-x1. This could then be solved, and the period of the solution can be obtained.
What a know/think!
number 1??
I THINK.. it is
we know F=KX & W=MG
since F=W, KX=MG
so K*d=2kg*G also K*(d+2.5cm)=2.253kg*G
so K=(2kg*G)/d also K=(2.253kg*G)/(d+2.5cm)
then (2kg*G)/d = (2.253kg*G)/(d+2.5cm)
we solve for d: (d+2.5cm)/d= (2.253kg*G)/(2kg*G)
G cancels out: (d+2.5cm)/d= 2.253kg/2kg
so 1+(2.5cm/d)= 2.253/2
2.5cm/d= 2.253/2-1
d= 2.5cm/(2.253/2-1)=
now that you have d and d+2.5cm
you can plug into equation F=KX or K=F/X which is K=MG/X
use K=MG/X
K=2kgG/d you know G and d so you have K which is spring constant.
K=99.2N/m
Number 2..
NOT A CLUE..
PLEASE HELP
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
