Physics question (mass at rest raised to height by force. What is velocity)?
To solve the physics problem involving a mass raised to a height by a force, the work-energy theorem is recommended. The equation FΔy = ΔK.E. + ΔG.P.E. can be applied, where G.P.E. is calculated as mgy and K.E. as 1/2 mv². Given the parameters of mass (10 kg), height (12 m), and force (200 N), the relationship between work done and energy changes must be established. Clarification on the problem statement is suggested for better understanding. This approach will lead to determining the velocity of the mass once raised.
bearsa113609
m=10k
h=12m
F=200N
a=v/t
F=ma
I cannot find the remaining equations to completely work the problem.
I recommend using the work energy theorem. For a constant force it will be
F \Delta y = \Delta K.E. + \Delta G.P.E
where G.P.E. is gravitational potential energy and is equal to mgy . And K.E. is kinetic energy and is equal to 1/2 mv^2
(And please try next time to explain the problem a bit more clearly) :wink:
