Physics Relativity/Power Question?
  • Thread starter Thread starter justinh8
    Physics
To determine the number of fusion reactions needed to generate 3 x 10^3 MW of thermal power, the calculation involves dividing the power output (3.0 x 10^9 J/s) by the energy produced per reaction (2.808 x 10^-12 J). This results in approximately 1.0683 x 10^21 reactions per second. The calculation confirms that the units are consistent, yielding reactions per second as the final result. The discussion emphasizes the importance of expressing answers clearly in relation to the question asked. The conclusion is that the calculations and units used are correct.
justinh8
Physics Relativity/Power Question??
When a fusion power reactor is possibly created, it is expected to produce about 3 x 10^3 MW of termal power. If a fusion reaction produces 2.808 x 10^-12 Joules, how many fusion reactions must occur per second to generate this power?
What i did was 3 x 10^9 J/s / 2.808 x 10^-12 J. But my problem is that if i do that i will only get seconds and not reaction per seconds. Please help.
The key to the question is in red above. So presumably the answer will have units s-1.
When you do your calculations, looking an the units, it is (Js-1) divide (J) which gives s-1, which seems like a good start.
By the way, the "reactions" in "reactions per second" is a count, so has no dimensions.
Ok, can you tell me if this is correct: N = the number of reactions and Eo = 2.808x10^-12J
P = 3.0 × 10 ⁹ W = 3.0 × 10 ⁹ J / s
P = E / t --> E = P t
E = N E₀ --> N = E / E₀
N = P t / E₀ … --> … N / t = P / E₀ = [ 3.0 × 10 ⁹ J / s ] / [ 2.808 × 10 ^⁻ 12 J ]
N / t = 1.0683 × 10 ^21 / s
Is this correct?
Is this correct?
it looks to be about the right size.
EDIT: Though you were not asked for the value of N/t, you were asked "how many fusion reactions per second, so a better answer would be
There would be 1.0683 × 10 ^21 fusion reactions per second.
If a question is asked in words, it should be answered in words.
If the question was "what is the number of fusion reactions per second, then you would give just the number.
Did i do it correctly in terms of the units? So basically isn't it just 3.0 × 10 ⁹ J / s / 2.808 × 10 ^⁻ 12 J?
Yes.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
