Physics - Single Slit Diffraction
jakeswu
Hi Guys, my textbook mentioned that how the equation for the minima for single slit diffraction was derived:
Consider a slit of width W with 2 light rays, one emitting from the edge, one emitting from the center. Their path difference is W/2 sin T . If the path difference is 1/2 lambda, then they will experience destructive interference. Same can be said for light rays spaced apart by W/3, W/4, so on. Hence the general equation for the minima, W sin T = m (lambda).
This is perfectly reasonable. However, I say:
Consider 2 light rays emitting from the single slit at each edge. Path difference will be W sin T. If W sin T were an integral multiple of wavelength, there should be constructive interference. So W sin T = m lambda can be the equation for constructive interference too.
Why is it that light rays spaced apart by the entire width of the slit aren't counted?
A less cheating derivation would take the interference between all pairs of rays into account. Usually this is done using Huygen's construction, eg. eq 7.2 in http://phyweb.phys.soton.ac.uk/quantum/lectures/waves7.pdf has an integral over the entire slit width.
In other words, if the positions across the slit are x=0 through x=W, then the rays coming from x=0 and x=w/2 interfere destructively. So do the rays coming from x=d and x=w/2+d where d is a small increment. So do the rays coming form x=2d and x=w/2+2d. Etcetera. The rays coming from all positions across the slit can be put into pairs like this, each with the path difference (w/2)sin(theta). Each pair cancels destructively, so the net result is complete destructive interference.
However, I say:
Because there is only one such pair of light rays. None of the other light rays emerging from the slit can be put into such a pair, that cancels destructively.
