Picard's Method for Solving Differential Equations: Finding y1 = 1 + x
  • Thread starter Thread starter trojansc82
    Method
trojansc82
y' = -y , y(0) = 1
Picard's method
I found y1 as 1 + 1/2x2, however y1 is really 1 + x
trojansc82 said:
y' = -y , y(0) = 1
Picard's method
Neither of those is correct for the equation you wrote. Show us what you did so we can find your mistake(s).
you should show you method, so we can see where you're going wrong - what was your first approximation? starting with a constant should integrate to a constant times x and you should have the solution after one iteration
also as LCKurtz points out neither is correct, you should alway check by substituting into the original DE
Sorry I meant y1 is really 1 -x. It was a typo.
I think LCKurtz and lanedance are misunderstanding your notation. Neither y= 1+ x^2/2 nor y= 1+ x is a solution to the equation but you are not claiming it is.
Picard's method of solving the differential equation y' = f(x,y), with initial condition y(0)= y_0 is an iterative method. Taking y_0 to be the initial value, y_1= \int f(x, y_0)dx is the first iteration, then y_2= \int f(x, y_1(x))dx, y_3= \int f(x,y_2(x))dx, etc.
For the problem as given, the first iteration of Picard's method is, indeed, y_1(x)= x+ 1. But no one can show you where you went wrong until you show us what you did.
Nor are we claiming that.
No, it isn't.
Oh, I completely misread the equation! It is y'= -y, not y'= y as I was seeing!
My apologies to both LCKurtz and lanedance.
trojansc82, I still don't see how you got "1+ x^2/2". Please show us what you did.
Again, I apologize, I mistyped the answer.
The answer for y1 = 1 - x
Is that the answer you got? In your original post you said you got something else. Have you figured it out? You never did show us what you did...
Within the integral I multiplied -1 (since y was -y) by t. I ended up integrating -t, which came to -1/2 x2.
I have trouble within the integral.
What integral? We aren't mind readers. My guess is you have the integral wrong in the first place. Show us your work.
