What is the correct way to wire a piezoelectric circuit on a breadboard?
The discussion revolves around difficulties in wiring a piezoelectric circuit on a breadboard to activate an LED using pressure. The user reports that the LED remains lit without pressure applied, indicating a potential wiring issue. Suggestions include ensuring a 1MΩ resistor is used and connecting the LED to pin 3 of the 555 timer instead of pin 5. Additionally, the output from the LM108 should be measured to verify if it can drive a power MOSFET. The conversation emphasizes checking wiring connections and component placements for proper functionality.
A31415
Hi, I am having trouble implementing a circuit diagram onto a breadboard. The circuit involves a piezoelectric ceramic, which when pressure is applied, it should create enough power to activate 9V and light up an Led for a second. When I put the circuit together on the breadboard, to the best of my ability, the LED was already lit by the battery and nothing happened when pressure was applied to the piezo. Here is the link for the circuit diagram: http://circuitswiring.com/trigger-555-monostable-circuit-using-the-piezo-transducers/
I have attached the photos of the circuit below. What am I doing wrong?
Thanks!
I cannot see the resistor from the piezoelectric ceramic to V+, but it has to be very large (at least 1MΩ). Here is a circuit diagram I found:
I tried the 1M Ohm resister and the same issue occurred.
For the circuit you suggested. Where would the power, that I am using the piezoelectric to activate, connect?
Thanks!
The output pin (pin 6) of the LM108 has an amplified version of the signal from the transducer. Measure it and if it is large enough, use it to drive a power MOSFET or something.
Did you put it here ?
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
