Hello ldesai149,
Welcome to Physics Forums!
ldesai149 said:
True or False: If a pinhole camera casts on the screen an image of 40.0cm in size of an object situated at a distance of 40.0m from the camera, then the size of the object is 10.0m.
M = hi/ho = di/do
hi = 40.0cm
do = 40.0m
ho = 10.0m (?)
M = hi/ho = 0.04m
di = dohi/ho = 0.16m
There's a mistake above involving what's in red. But read below before reaching a final conclusion in your answer. You used
ho = 10 m as part of your calculations, but you shouldn't use a specific number for
ho, because you don't know for sure what the object height actually is yet.
M = di/do = 0.004m
I'm guessing it is FALSE because the two values for M are different but I really have no idea how to go about a question like this. Any help would be greatly appreciated! :D
This is a true or false question. So at the time the statement is given, you don't really know what the object height
ho is. Maybe it's 10 m if the statement is true. But maybe it's 12 m or 100 m, or some other height, if the statement is false. It's best not to use a specific value for
ho unless you can derive that value first.
Since you don't know what
ho is, is there a way to calculate it knowing
only that
hi = 0.40 m, and
do = 40 m? If, based only on that information, you can calculate
ho to be 10 m (without using "10 m" as part of your calculations), then the statement is true. If you calculate some other number
or if there is simply not enough information to derive the 10 m figure, then the statement is generally false.
