Solving Pinned Jointed Frame Exterior Reactions
  • Thread starter Thread starter matthew_hanco
    Frames
The discussion revolves around calculating the exterior reactions for a pinned jointed frame, focusing on the correct application of equilibrium equations. The user initially struggles with determining horizontal and vertical forces, assuming values for HA, VA, and HE. A peer points out errors in moment calculations and emphasizes the need for accurate dimensions in the free-body diagram. After adjusting the calculations based on feedback, the user realizes the correct resultant reaction force at point A is 22.20 kN at an angle of 26.77 degrees from the horizontal. The conversation highlights the importance of precise dimensions and proper moment sign conventions in structural analysis.
matthew_hanco
The problem is attached to this post, basically i need the exterior reactions and how to work them out.
i know i need to take moments I am just not sure how to work it out.
Basically what i worked out
is
i assumed horizontal members are equally to 1
sum of the horizontal = 0 5Kn- HA - HE=0
Sum of the vertical =0 10KN- VA =0
But that is where I am stuck i know the numbers should be roughly
HA=20
VA= 10
HE = 15
But i know it is more accurate than that I am not sure if i need to include sine or cosine in the solution
Thanx in advance
To add to it i have just tried
sum MA= 0
Therefore he x 2 - 5x1 - 10x2 =0
he =12.5
sum of horizontal 5+12.5 =17.5
therefore ha = -17.5
sum of the vertical
Va -10 x 1 =0
so Va = 10
Is that right?
Im desperate and really need someones help urgently.
matthew_hanco said:
sum MA= 0
he =12.5
Hi matthew,
Since you're taking moments around A and since the 5 kn and 10 kn forces produce opposite moments around A, one of your terms needs to be positive and one needs to be negative. You have a negative moment around A for BOTH of these forces.
Once you get the horizontal force from E you can sum forces and get the horizontal and vertical forces on A.
ok so the new calculated resultant forces would be
He= 15 ( (-10 x 2) - (+5x1) + He=0)
Ha= -20 (+15 + 5 - ha= 0 therefore Ha= -20)
Va= -10 (+10 -Va=0)
But now checking my lecturers answers he gives
14.82 for He
And a resultant force for a 22.2 acting 26.46 degrees from the horizontal
But with my results the resultant for a is 22.36 and 26.56 from the horizontal.
who is right, if he is how can i account for the discrepencies
Those answers are all pretty close, so I would guess the differences are in rounding error. Regardless, I can't check the math because the figure you provide has no dimensions on it.
All forces are in KN
I can see the forces. There are no linear dimensions on your picture.
matthew_hanco: The dimensions are already fully defined by the diagram given in post 1. The resultant reaction force at point A from your lecturer, 22.20 kN, is correct. However, the orientation angles given by both you and your lecturer are currently incorrect. The resultant reaction force at point A is 22.20 kN acting 26.77 deg from the horizontal. Keep trying. Your discrepancies are not due to round-off error. First, figure out the correct dimensions of your structure, and label them on your free-body diagram. You currently appear to be using wrong dimensions.
Got it, the length should be root 3 instead of 1.
so it should be
(-10 x (root3x2) - +5x1)/2=Ha
Excellent, matthew_hanco.
