Planck's constant in planetary orbits
5 replies · 4K views
QuantumBlink
The question is:
If quantum mechanics were detectable in planetary orbits, how much larger than the currently accepted value would Plancks constant need to be?
Relevant equations
ΔxΔpx ≥ħ/2
p=mv
Earth-Sun dist 1.496E11
Earth orbit speed 28,900ms^-1
Earth mass 5.972E24 kg
The attempt at a solution
Δx=1.496E11
Δpx = 28,900ms^-1*5.972E24 kg
h= 4π Δx Δpx
h≈3.38E41 Js
I'm not sure I've I've gone about this question correctly, it's worth a considerable amount of marks so am unsure if it's a suitable solution.
How are you defining Δp and Δx?
Defining Δx as the Earth Sun distance and Δp as the momentum of the Earth (mv), I wasn't sure how to do it any other way with the information given ?
... and, how are those quantities defined and used in the expression describing the uncertainty principle?
QuantumBlink said:
Relevant equations
ΔxΔpx ≥ħ/2
So oddly enough I have almost the same question, except ours is a bit less precise in the values of the Earth-Sun distance etc.
So I was taking the approach that:
Δp=p1-p2
Hence
Δp=m1v1-m2v2
One would assume m is constant and so m1=m2, while v is an average and there are minor fluctuations. Thus we have:
p1-p2=m(v1-v2)​
when you take the differential of that, m being a constant disappears so we get Δp=Δv
Similar treatment with Δx leads to:
Δx=Δd
where d=Earth-Sun Distance
From there you would solve the inequality for ħ then use ħ=h/2π
However I'm concerned I've been thinking about the Δ meaning wrong and hence come to the wrong conclusion, however in my problems last week with the uncertainty principle my demonstrator indicated I can't just assume Δp=p for whatever I'm doing, but I'm realizing now I'm a little fuzzy on the reasoning.
Am I on the right track here?
edit:
I've realized I've had brain fart (not actually had to do any calculus since first year >.> ) and the m doesn't magically disappear, so Δp DOES equal p in this case, since it would be mΔv, and here Δv=v, I think.
Having subbed in all the values I get the same answer as QuantumBlink is greater than h, so...
for quantum effects to be detectable (i.e. effects due to the uncertainty principle), h should be strictly greater than 3.38x10^41, I think?
So in general Planck's constant would need to be 75 orders of magnitude larger.
