A Plasma physics - relativistic derivation
SMannion
Hello,
I am trying to work through attached paper, deriving from equation 2.2 to 2.4. I am not familiar with the notation. If I try and get the integral of inside the <> brackets, I end up with a different eqn 2.4.
I need some maths help here :)
Any help would be greatly appreciated.
Sinéadhttp://www.jetp.ac.ru/cgi-bin/dn/e_049_03_0483.pdf
What do you get?
And how did you get it? If you show your working, someone may be able to point out any mistakes.
Note that you can write equations using LaTeX, according to https://www.physicsforums.com/help/latexhelp/ .
We start from the dispersion equation for the longitudinal oscillations
$$\epsilon(\omega,k)=0 (2.1)$$
with the following expression for the permittivity
$$\epsilon(\omega,k)=1-\omega_p^2\langle \gamma^{-3} (\omega-kv)^{-2}\rangle (2.2)$$
It is assumed that the perturbations depend on the coordinates and on the time like ##exp(-iwt + ikz)##.
The direction z is arbitrary in the absence of a magnetic field, and coincides with the direction of the intensity vector
of this field if such a field is present in the plasma.
The symbol <> denotes averaging over the particle momenta, ##<(. . . )> = \int f_0(p )(. . . )dp/n, n = \int f_0,(p)dp## is the plasma density, ##f_0(p)## is the equilibrium particle momentum distribution function (one/dimensional), ##\gamma = (1 +p^2/m^2c^2)^{1/2} ## is the relativistic factor, ##v = c(1 +m^2c^2/p^2)^{-1/2} ## is the particle velocity, m is its mass, ## \omega_p^2: = 4\pi e^2n/m ## is the square of the plasma frequency, and e is the particle
charge.
We confine ourselves to a one-dimensional particle distribution in momentum (the case of greatest interest
for applications to the pulsar problem). We find with the aid of (2.1) and (2.2) that the longitudinal oscillations have a phase velocity equal to that of light, ## \omega/k= c## at ##k = k_0##, where ##k_0##, is defined by the relation ##k_0^2= 2\omega_p^2 <\gamma>/c^2##. In this case ##\omega = \omega_0=ck_0##,. Using this result, we can obtain by successive approximations(cf. Refs. 6 and 7) a solution of (2.1) with wave numbers close to ##k_0##. Assuming ##k+ k_0+\Delta k, \omega =\omega_0+\Delta \omega,## where ##\Delta k## and ##\Delta \omega## are small quantities, and taking into account
the result of the zeroth approximation ##\epsilon(\omega,k)=0## we obtain in the first approximation
$$\Delta \omega = -\bigg ( \frac{\frac{\partial \epsilon}{\partial k}}{\frac{\partial \epsilon}{\partial \omega}}\bigg)_0 \Delta k (2.3)$$
The zero subscript in the right/hand side of this equation means that the corresponding derivatives are taken at ##k = k_0, \omega = \omega_0##. In this case
$$\bigg(\frac{\partial \epsilon}{\partial \omega} \bigg)_0=\frac{2\omega_p^2}{k_0^3 c^3}\bigg\langle \gamma^{3} \bigg(1+\frac{v}{c}\bigg)\bigg \rangle^3, \bigg(\frac{\partial \epsilon}{\partial k} \bigg)_0=-c(1-\alpha)\bigg(\frac{\partial \epsilon}{\partial \omega} \bigg)_0, \alpha=\bigg\langle \gamma \bigg(1+\frac{v}{c}\bigg)^2\bigg \rangle \bigg/ \bigg\langle \gamma^{3} \bigg(1+\frac{v}{c}\bigg)\bigg \rangle^3$$Phew that took 2 hours to type!
I took the ##\partial \epsilon / \partial \omega## to start with, I think I'm missing something with the <>. The ##\bigg(\frac{\partial \epsilon}{\partial \omega} \bigg)_0=...\bigg\langle \gamma^{3} \bigg(1+\frac{v}{c}\bigg)\bigg \rangle^3 ## is not inverted in my case. Please any help would be much appreciated...
Likes berkeman
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
