Oxyhydrogen Welders: Educate Me on Single Phase Power
  • Thread starter nottoobright
In summary, the conversation is about oxyhydrogen welders and the user's request for information about them. They are wondering about the required amps to run one and if it can be run on single phase power. The speaker clarifies that oxyhydrogen torches usually run on compressed gas, not generated through electrolysis. They also mention the dangers of using H2/O2 in a stochiometric ratio and suggest asking in a welding forum for more information.
nottoobright
Hello there,
I have little knowledge in the field of physics and respctfully request the more intelligent user to impart some to me.
Oxyhydrogen welders. What sort of amps are required to run one? Can they be run on single phase power?
Came across one and, probably erroneously, concluded that the required amps must be huge as water is electrolysed, and recombines to form the flame. I realize there are many on the market but they seem to weigh a tonne and require an enormous power supply.
Is there a way of running one of these things on household/ single phase power?
Much obliged,
Ike.
Oxyhydrogen torches generally run on compressed H2 / O2 gas. I hadn't heard of any that generate gas by electrolysis.
Generally you use oxyhydrogen for delicate jewelry type work so you wouldn't need a very large flame or large gas supply.
thanks.
clearly I didn't understand what I am trying to buy -
please look at this link and tell me if the HHO mix is produced from electrolysis? (note it doesn't mention the required amps).
many thanks for your help
Ike.
It's perfectly possible to generate H2 / O2 from electrolysis of water - it's just that it's also pretty cheap to buy as a compressed gas.
There are some slightly worrying bits of the ad if you were thinking of parting with money- like where he invented water !
Aquygen™, also known as HHO, is an evolutionary industrial gas invented by our Founder and Chairman Emeritus, Dennis Klein.
It also mentions using them to boost car fuel consumption - this is a common perpetual motion machine scam. Use the car alternator to split water into H2/O2, burn water in engine, generate electricity to split... etc
The only other thing I would be concerned about is that this must generate H2/O2 in a stochiometric ratio (ie exactly the correct amount of hydrogen to burn back into water) generally you want one of the componnets in excess to make sure that all the fuel reacts. I might be a little concerned that you need more oxygen to ensure that all of the H2 burns - otherwise you might have a build up of H2 in air(not good)
You probably want to ask in a specialised welding forum - unless somebody here has more experience.
Related to Oxyhydrogen Welders: Educate Me on Single Phase Power
1. What is an oxyhydrogen welder?
An oxyhydrogen welder, also known as an oxyhydrogen torch or oxyhydrogen flame, is a type of gas welding tool that uses a mixture of oxygen and hydrogen gases to produce an extremely hot flame for welding and cutting metal.
2. How does an oxyhydrogen welder work?
An oxyhydrogen welder uses the chemical reaction between oxygen and hydrogen to produce a high-temperature flame. The gases are mixed and ignited, creating a flame with a temperature of over 5,000 degrees Fahrenheit. The heat from the flame can then be used to melt and join metal pieces together.
3. What is single phase power?
Single phase power is a type of electrical power distribution in which all the voltage variations occur in a single waveform. It is commonly used in residential and small commercial settings and is distinguished from three-phase power, which has three voltage waveforms.
4. Can an oxyhydrogen welder be used with single phase power?
Yes, oxyhydrogen welders can be used with single phase power. However, they typically require a higher amount of power to operate compared to other welding tools. It is important to check the power requirements of your specific oxyhydrogen welder to ensure it is compatible with your single phase power source.
5. What are the advantages of using an oxyhydrogen welder?
Oxyhydrogen welders have several advantages over other welding methods. They produce a clean flame, which results in less smoke and fumes compared to other welding techniques. They also have a high heat concentration, making them ideal for precise welding and cutting. Additionally, oxyhydrogen welders do not require an external power source, making them portable and ideal for use in remote locations.
  • Other Physics Topics
  • General Discussion
  • General Engineering
