Please explain the short lifespan of LIPUS devices....
  • Thread starter Thread starter John Bartle
    Explain Short
The discussion centers on the short lifespan of LIPUS devices, specifically the Exogen model by Bioventus Global, which is rated for approximately 300 uses at 20 minutes each. Participants speculate that the limited lifespan may be due to the battery or transducer components, with concerns about the transducer's durability after only 6000 minutes of use. There is skepticism about the transparency of customer support regarding the device's longevity, with suggestions that manufacturers might not fully disclose potential issues. One user proposes testing the device's functionality using graphite powder to ensure it operates correctly. Overall, there is a strong emphasis on understanding the reasons behind the device's limited lifespan before making a purchase.
John Bartle
So far, I have only seen about 3 LIPUS (Low Intensity Pulsed Ultrasound) devices that are commercially available. The one that I am looking at right now is made by Bioventus Global and it is called Exogen.The " http://www.exogen.com/us/patient-resources ", on Bioventus Global website, states that their LIPUS device only has a lifespan of about 300 uses at 20 minutes per day.
The only components that I can think of that would cause such a short lifespan are the batteries and transducer.Which components would likely be causing such a short lifespan ?
If it is the transducer that is wearing out, is it normal for ultrasound transducers to wear out with only about 6000 minutes of usages ?
If it is the transducer that is wearing out, which part of the transducer ?
Thanks.
the battery
Likes John Bartle
@davennThe reason for original post was that this is kind of important.
I need a LIPUS device, and if it should stop producing the ultrasound waves or the wrong waves I don't suppose that I would ever even realize it... I would happily just go about changing the battery and using the LIPUS device, for years on end, believing that it is working when in reality it is not.
So, given your post, I will assume that the transducer does not wear out, and that I only need to worry about the battery.Thanks.
Perhaps you could test functionality by using graphite powder on a sheet of paper. I suppose it should generate resonance patterns.
Yes, I suppose I could do that.
In my original post, one of a number of reasons why I posted was that I was hoping to get a concrete idea of why a LIPUS device would wear out so quickly - before purchasing it.
But, of course, yours is an excellent idea. Thanks.
When you called their Customer Support folks, what did they have fo say?
Likes berkeman
I admit that I have not spoken with them yet. I called today and they will not be available until Monday.
On Monday I intend to call them again.
In this case, I don't entirely trust what the customer support might say. It - may - be in their interest to not fully divulge why their product only last for about 6000 minutes. One reason that I slightly suspect this is because their reasons were not clearly divulged in their online reading material. So, I simply wanted both their explanations and this forum's. Also, I assume that electrical engineers could possible give more involved and technical explanations. See, I was hoping to purchase an Exogen device and have it fixed if it breaks, but I need to know a little bit about what is likely to break.
It cannot be ruled out, that they intentionally break after a certain lifetime. They could e.g. use electronic components of minor quality. A broken resistor or capacitor would probably do. Battery replacement seems to me a too obvious and easy to repair reason to publicly admit a 100 h lifespan.
This is a prescription medical device. It was tested clinically to the indicated lifespan. Use beyond that is not medically guaranteed.
That said, it is likely only at a small percentage of its useful life. They say to call customer support after 300 uses. They may just have you do some sort of calibration and you get 300 more uses if everything checks out.
BoB
Likes John Bartle
