Please explain why one of the integral vanishes
  • Thread starter Thread starter yungman
    Explain Integral
The discussion centers on the evaluation of a vector integral related to an elemental magnetic dipole, specifically why a certain integral vanishes. Participants clarify that the integral involves a vector field, and the direction of the vector changes around the loop, leading to cancellation of contributions from opposite points. It is emphasized that the integrand cannot be treated as a constant due to its varying direction, which is crucial for understanding the integral's behavior. The integration should consider the vector's components rather than treating it as a scalar. Ultimately, the consensus is that the integral vanishes due to geometric symmetry and the nature of vector fields.
yungman
[PLAIN]http://i45.tinypic.com/2jfabf8.jpg[/PLAIN]
This is a elemental magnetic dipole. The book shows how to find the vector magnetic potential at any distance from the origin. If you read the bottom, it said the second integral in 11.24 is obviously zero. It is not obvious to me.
##d\vec l'\;=\;\hat {\phi} bd\phi##. The second integral is
##\oint d\vec l'\;=\;\int_0^{2\pi} d\vec l'= \hat{\phi}2\pi b##. It is not zero.
Please comment on this.
Thanks
Alan
##\oint d\vec l'\;=\;\int_0^{2\pi} d\vec l'= 2\pi b##. It is not zero.
This can't be right, the integrand is a vector, and the result you state is a scalar. The integral is like a vector sum- what do you get when you add up all the tangent vectors to a circle going around the loop? (think about the vector sum around a polygon)
Well a curl free vector field integrated around any closed curve always gives 0.
A constant vector field is of course curl-free
It's direction is changing with space so it obviously isn't a constant vector not to mention you are using heavy machinery to show something so simple. The poster above you already gave the most simple reason for why the integral vanishes.
Thanks for the reply. I forgot to put in the ##\hat \phi##. So how do you integrate a vector? I am confused about this:
If I translate ##\hat{\phi}=-\hat x \sin \phi+\hat y \cos \phi## and then integrate from 0 to ##2\pi##, then I get zero. But if I leave the vector as ##\hat {\phi}##, it is like my original post.
Split it into a double integral in each component.
What do you mean? There is only single integral with ##\hat{\phi}## as the component. Please read the post again as I added another part in a few seconds ago.
How about a simple appeal to geometry? For every dl vector, there is cancellation from an opposite-pointing vector on the opposite side of the circular loop. This is what Hechima was getting at back in Post #2, and I suspect what led the author to say the integral "obviously vanishes".
But if you are determined to slog through the math:
Yes, exactly.
[STRIKE]Are you are taking the ##\hat {\phi}## factor out of the integral, as you would a constant factor? You can't do that, it's not constant owing to it's changing direction (it's a vector, remember). To clear this up, perhaps you could rewrite your integral including the ##\hat {\phi}## -- you say you left it out earlier, so it is not clear to me what you have done at this point. Then again, I am a little tired at the moment.[/STRIKE] [EDIT: I see you already made the change, never mind this striked-out part.]
Okay, you had
But that 2nd integral isn't quite right. dl is not going form 0 to 2π -- Φ is. As in Φ the scalar angle as one goes around the loop. So the variable of integration should be Φ (the scalar, not the unit vector) in that second integral.
Since ##\vec{dl'}## has a magnitude of ##b \ d \phi## and direction ##\hat{\phi}##,
\oint d\vec l'\;=\;\int_0^{2\pi} b \ \hat{\phi} \ d \phi
It's important to remember that ##\hat {\phi}## changes direction, therefore it is NOT a constant and can NOT be take outside the integral.
I can't think of a better way to evaluate the integral than to write ##\hat {\phi}## in terms of its x and y components, which it appears you have already done.
Hope that helps.
