Exponential Probability Density of Electron in 1D Potential Well
  • Thread starter Thread starter lozzyjay
lozzyjay
An electron is in a 1 dimensional potential well. If the energy of the electron is < V0, show that the probability density P(x) for the electron falls exponentially:
P(x) = Aexp(-x/L)
I honestly have no clue, I've been trying all day to do this!
You need to show us what you have been doing "all day", so that we can help to guide you in the right direction. What is the basic equation that you should be using to approach this problem? It has a catchy name...
\frac{-h bar^{2}}{2m} \frac{d^2\psi}{dx^2} = (E - V_{0})\psi
So that's the schrodinger equation for when the energy is less than V0 I think...
Then to show the probability density...
P(x) = \int\psi(x)* \psi(x) = 1
I have no idea what to do next...
Ok, so the schrodinger equation is psi''=k*psi, where k is a positive constant. What do the solutions to that equation look like?
The solutions are of the form
\psi = Ae^{ikx} + Be^{-ikx}
Noooo. The k in psi''=k*psi is real and positive. How about A*exp(sqrt(k)*x)+B*exp(-sqrt(k)*x)?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
