How Do You Solve Complex Ratio Problems in Chemistry?
  • Thread starter Thread starter roger12
    Ratio
To solve complex ratio problems in chemistry, it's essential to understand the relationships between the components involved. In the first problem, A is 3/8 of the total compound, leaving 5/8 for B and C, which are in a 1:2 ratio. This means B and C must be calculated based on their combined fraction of 5/8, where B is 1/3 of that and C is 2/3. The second problem involves ratios A:B=1:7 and B:C=13:9, which require finding a common variable to express all components in a unified ratio. Properly setting up these relationships is crucial for determining the correct proportions of A, B, and C.
roger12
In each of the following the properties of a compound are given. In each case find A:B:C
1. 3/8 of A with B and C 1:2
2. A, B, C are mixed according to the ratios A:B=1:7 and B:C=13:9
I just can't seem to solve these two. I got no idea where to even start. Please help.
I'll help but show an attempt.
1. You know A is 3/8 of the compound, so how much is left over for B and C?
So that leaves 5/8 of B and C which are in the ratio 1:2.
Would then be:
3/8 of A, 5/8 of B and [ 5/8]/2 of C
roger12 said:
Would then be:
Not in the way I'm reading your problem. Does the numbers you have "assigned" for B and C, added together, give you 5/8? It does not.
If you have, say, X and Y in a ratio of 1:2, that means that X has to be 1/3 of the whole, while Y is 2/3 of the whole. Use this hint to figure out what fractions go with B and C if together they are 5/8 (of the compound).
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
