[Point Charges] Can't figure this out
The discussion revolves around calculating the net electrostatic force on particle 7, surrounded by six charged particles. The calculations involve breaking down the forces into x and y components, applying Coulomb's law, and simplifying the expressions for each force. Despite multiple attempts, the calculated force values consistently yield results that are deemed incorrect, with participants expressing confusion over discrepancies in their calculations. A suggestion is made to express the forces in relation to the force between particle 7 and one of the other particles to simplify the process. Ultimately, the participants are seeking clarity on the correct approach and values to arrive at the accurate net force.
Gr33nMachine
In the figure below, six charged particles surround particle 7 at radial distances of either d = 1.0 cm or 2d, as drawn. The charges are q1 = +8e, q2 = +8e, q3 = +e, q4 = +8e, q5 = +8e, q6 = +4e, q7 = +4e, with e = 1.60 10-19 C. What is the magnitude of the net electrostatic force on particle 7?---2----
1-7-3-4
---5----
---6----
F = k(q1)(q2)/(r^2)
k = 8.99e9
I split this up into x and y components, and then figured out the sum.
For the x, ƩF = |k(q7*q1)/(r^2) - k(q7*q3)/(r^2) - k(q7*q4)/(4(r^2))|
This simplifies to: |[k(q7)/(r^2)]*[q1-q3-q4/4]|
and so ƩF = |[4ke/(.01^2)]*e(8-1-8/4)| = 4ke/.0001*5e = 20k(e^2)/.0001
I used the same process for the y component. 2 and 5 cancel out since they have the same distance and charge, so the only charge I needed to calculate was for 6. F = k(q7)(q6)/(4(r^2))
This simplifies.. F = k(6e)(4e)/((4)(.0001)) = 6k(e^2)/.0001
Now the net charge is ([20k(e^2)/.0001]^2 + [6k(e^2)/.0001]^2)^.5
Simplify this to [436(k^2)(e^4)/(10^-8)]^.5 which comes out to 4.8055e-23, which webassign says is incorrect.
---2----
1-7-3-4
---5----
---6----
F = k(q1)(q2)/(r^2)
k = 8.99e9
I would have calculated the force between q7 and q3 [since q7 is the central charge we are analysing and q3 is just a single e. [lets call that F]
You can then express every other force in terms of that F
eg q1 is the same distance, but q1 is +8e so the force is 8F
q4 is the same size as q1, but twice the distance , so 2F [inverse square law]
etc.
etc.
So, ƩFx = F + 8F + 8F/4 and ƩFy = 4F/4
ƩF = (11F^2+F2)1/2
ƩF = (122F2)1/2
F = k(4e)(e)/(.012) = 4ke2*.012
ƩF = 1.0168e-30
This doesn't seem right since it's 7 degrees off my previous calculations.
ƩF = (11F^2+F2)1/2
ƩF = (122F2)1/2
ƩF = 1.0168e-30
The x-direction 8F force is in the opposite direction to the other two.
Ahh... so ƩF = (5F2+F2)1/2 = (26F2)1/2
This still results in a suspiciously large exponent: ƩF = 4.694e-31
Is the "real" answer of the order of 10-22 by any chance?
ƩF = (11F^2+F2)1/2
ƩF = (122F2)1/2
ƩF = 1.0168e-30
Looks like a divide changed to a multiply ??
Wow. All I can say is, stay off drugs, kids.
edit: So I ended up with a value of 1.016e-22, and it's STILL not right. I've run out of chances now, but I'm still interested in knowing what I'm doing wrong here.
