Poisson distribution question
The discussion focuses on calculating the probability of exactly 3 out of 20,000 babies having a chromosome mutation using the Poisson distribution. The formula used is e^(-np) * (np)^k / k!, with p set at 1/10,000 and n at 20,000. It is clarified that for the specific question of exactly 3 mutations, only k = 3 needs to be calculated. If the question were about at most 3 mutations, then the probabilities for k = 1, 2, and 3 would need to be summed. Understanding the question's requirements is crucial for applying the correct approach.
semidevil
ok, so on average, there is a chromosome mutation link once every 10,000 baby births.
approximate the probability that exactly 3 of the next 20,000 babies born will have the mutation.
so using poisson distribution, I let
p = 1/10,000
n = 20,000.
and use formula (e^(-np) * (np)^k / k!
so when I do the calculation, do I sum it all up for k = 1, 2, 3, or do I just calculate k = 3 and that is my final answer?
if they ask at most 3, then I would sum up k = 1, 2, 3 right?
I first applied the formula for k = 1, 2, 3, but then it got me thinking about it...
Your approach is correct. You would use the Poisson distribution formula to calculate the probability of exactly 3 babies out of 20,000 having the mutation. This would involve calculating the probability for k = 3 only.
If the question asked for at most 3 babies, then you would need to sum up the probabilities for k = 1, 2, and 3. This would give you the probability of 3 or fewer babies having the mutation.
It is important to carefully read and understand the question to determine which approach to use. In this case, the question specifically asks for the probability of exactly 3 babies having the mutation, so you would only need to calculate for k = 3.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
