lottie44442
- 5
Poisson's Ratio coursework - Urgent help needed!
hello,
I'm currently working on a coursework for my A2 physics on Poisson's ratio
i'm finding the ratio for aluminuim using aluminuim foil and strain gauges, adding masses to a clamp on the end of the foil (so foil is under tension) and getting a change in voltage using a Wheatstone Bridge circuit.
I have 2 questions, firstly, as I have never used strain gauges before, could you let me know if my set up sounds reasonable?
also, i know that to get Poisson's ratio, i need the tranverse strain divided by axial strain, but is this the tranverse strain the change in width/strain at 90 degrees to the force, or the change in cross-sectional area/ the change in width AND depth?
Thank you for your help! I'm really worried about the coursework and i really need a good grade to get into university!
(sorry for posting twice - i wasn't sure if i was in correct section)
hello,
