Polarization Charge on the surface of a spherical cavity
XCBRA
The polarizatiob charge on the surface of a spherical capacitor is -\sigma_e \cos(\theta), at a point whose radius vector from the centre makes an angle \theta witha given axis Oz. Prove that the field strength at the centre is \frac{\sigma_e}{3 \epsilon_0},
Well I not entirly sure how to approach this problem. I tried exapanding the potentials inside and outside the sphere as:
V_{in} = A_1 r \cos(\theta) + \frac{A_2}{r^2}\cos(\theta)<br /> V_{out} = B_1 r \cos(\theta) + \frac{B_2}{r^2}\cos(\theta)
Then since V_{in} \neq \infty, A_2 = 0 ,
then saying that at r=R: D^{perpendicular}_{in} - D^{perpendicular}_{out} = \sigma_f and assuming that both inside and outside have the same permitivitty then E^{radial}_{in} - E^{radial}_{out} = \frac{\sigma_f}{\epsilon_0}.A_1 + B_1 - \frac{B_1}{R^2} = \frac{\sigma_e}{\epsilon_0}
I am not entirely sure if I am aproaching this problem in the right way. Any help or advice on how to g o about solving this problem or problems like this would very much apreciated.
While I am sure there is some clever way to apply spherical harmonic expansion here, the problem is more straight forwardly done by just use integration. Just do a surface integral over the electric field contribution of each area element. There is clear azimuthal rotation symmetry so that you only needs to compute the z component. E_z = \frac{1}{4\pi \epsilon_0} \int \frac{\sigma(\theta) \cos\theta \, da}{R^2} \,, where R is radius of the sphere.
Fistly thank yo for your help. Secondly I am having trouble seeing how yuo get to this integral and then how you solve it. Am I correct in saying this is a result of Gauss' Law?
I have tried to compute the integral and i am unfortunately at a loss as to how to do this to get the desired answer:
= \frac{1}{4\pi \epsilon_0} \int\int \frac{\sigma(\theta) \cos\theta \, rdrd\theta}{R^2}
= \frac{1}{4\pi \epsilon_0} \int r dr \int \frac{\sigma(\theta) \cos\theta \, d\theta}{R^2}
here is where i am stuck. Do I take limits, and if so how do I determine them, I have tried taking r=R to r=0 and \theta = 0, 2\pi.? Thank you for you help.
You have the wrong area element of a sphere. It should be: da = R^2 \sin \theta d\theta d\varphi.
There is no variation in radial distance, so no dr.
Ah ok that makes a lot more sense, thank you for your help.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
