Position of particle in a box, is this a valid way to solve?
Monocles
This is problem 2.4 from Griffiths, where he asks to find the expectation value of the position of a particle in a box.
Schrodinger equation.
I wrote that
\frac{2}{a} \int_0^a x (sin(\frac{n \pi}{a} x))^2 dx = \frac{a}{2} + \frac{2}{a} \int_{-\frac{a}{2}}^{+\frac{a}{2}} x (sin(\frac{n \pi}{a} x))^2 dx = \frac{a}{2}
By argument of moving the origin to a/2 and that the integrand becomes odd when you do that, and so the integral equals zero. Is this valid, or do I need to tidy up the integral some more?
You need to be a bit careful here because the symmetric particle in the box potential admits both even and odd solutions, i.e. sines and cosines. I would recommend that you actually do the integral and use your argument not as proof but as validation why the answer a/2 makes sense.
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
