Position of third charged particle
To find the position of a third charged particle between two particles with charges +Q and +3Q, the forces acting on it must be equal. The initial attempt set up the equation correctly, but the solution yielded x = 0.366d instead of the expected d/9 (x = 0.111d). Participants noted potential errors in the approach, including misunderstanding the relationship between distance and force. The discussion highlighted the importance of correctly interpreting the problem statement and ratios involved. Overall, the consensus suggests a need for careful reevaluation of the calculations and assumptions made.
Voidy
Two particles are separated by a distance d, Particle A has charge +Q and Particle B has charge +3Q. At what distance from particle A along the line connecting particles A and B would you place a third charged particle such that no net electrostatic force acts on it ?
F = kq1q2 / r^2
Since there is no net electrostatic force on the third particle, the force from Particle A to C, and force from Particle B to C must be equal.
So I set up the equation
k(Q) / x^2 = k(3Q) / (d-x)^2
and solved for x using the quadratic formula.
I got
x = .366d
However, the answer is d/9, which is x = .111d
Can anyone help me ? Thank you
I get the same answer as you. The value can't be a rational fraction of the separation distance.
Note that they don't define d in the statement of the problem, yet they state their answer in terms of d. That's a clue right there that there's something amiss. Perhaps a typo!
I also agree with .366, but d is given.
The author seems to have made two errors:
Taken distance as inversely proportional to square of force, instead of the other way around;
Taken the ratio of the two distances instead of the ratio of the shorter distance to the total distance.
Very sloppy.
Oh, yeah, so it is. How'd I miss that?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
